Many people opt to not permanently install an A/C unit in their trailer. They'd rather haul them in and out only when thy feel it's needed. Here in Texas, an A/C unit is needed, often 8-9 months a year. So, I built mine into the rear bulkhead, so it would always be available. Even with all the extra ducting and peripheral gear my particular (peculiar?) installation required added in, I only added 55-65 lbs to total trailer weight, including drip tray (the unit itself only weighs 42 lbs). Since my trailer is over 1600 lbs, that isn't much. I bought the dimensionally -smallest sized unit, with simplest controls, I could find, so that if I ever needed to replace it with a slightly larger unit, I only need to enlarge the bulkhead hole where it resides. The 3/4" plywood holds it in firmly, without the vibrations most people associate with "window-shakers". It also has a start-up amperage of 4.8, and running at 4.6 amps, my on-board 2500 watt generator has no problem with it. It cools my un-insulated trailer very well, though the outside walls do sweat in the high humidity. I mounted my unit high up on the bulkhead, so the cool air could be circulated under the ceiling, and back at me indirectly (with or without a secondary fan). If I was to build another trailer, I would still use this type A/C , but sit it on the galley floor, with open access thru the hatch for exhausting, and any excess water wrung from the air would be directly dripped thru the floorpan (though, so far, my unit - like an 8k LG unit at home, seems to use up any excess without dripping).edgeau wrote:Another option I have seen is to mount a window unit in the bulkhead between the galley and bed. Remember it is a small space and you don't need much capacity.
Sent from my ZTE T84 using Tapatalk
Shadow Catcher wrote: One other process used heat and an adsorption chiller which could be powered by a camp fire or propane. There is nothing available commercial but wit a lot of development and it might be possible.
Here's one; I considered it after a minor racing heatstroke in 2005. Not too comfy while sleeping, I would think.Tomterrific wrote:I've had this idea for a long time, longer than most have been alive! As an efficient electric blanket warms by heating the body instead of the air, then a cool sheet would be ideal. You'll need to make your own as I know of none available. Use many feet of vinyl tubing, like aquarium air line, and attach it to the surface of a sheet. Pump cool water through the sheet.
Hey! You asked for creative ideas.
Tt
