The Astroliner
Re: The Astroliner
Postby Vedette » Sun Jan 29, 2017 6:10 pm
Oh Yah! :thumbsup:
Very popular choice.
IMHO one of the prettiest race cars ever built. :thinking:
Brian
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Re: The Astroliner
Postby Atomic77 » Mon Feb 06, 2017 8:35 am
Another Saturday in the books. More planning, figuring and spending money on materials! We're currently working on the built-in's; fridge, hot water heater and one of my favorite things so far... the pantry! Here's the fridge area going together:
With the wall face:
Shelves going together for the pantry:
We designed the pantry to slide on ball bearing sliders with soft close. It will hide in the wall :
And slid out:
That's it for now!
Sent from my SAMSUNG-SM-N915A using Tapatalk
Michael
The Astroliner
Check out our YouTube video
Atomic77
Images: 309
Re: The Astroliner
Postby KCStudly » Mon Feb 06, 2017 8:44 am
The arches really tie back into your overall theme, and the pantry should keep everything in place well while underway. Bravo! :applause:
Re: The Astroliner
Postby Atomic77 » Mon Feb 06, 2017 9:35 am
KCStudly wrote:The arches really tie back into your overall theme, and the pantry should keep everything in place well while underway. Bravo! :applause:
Thanks KC! We decided almost last minute to carry the archtops into the cabin. Without doors it seems almost drastic. But I think once the doors are installed they will blend in nicely. Storage in the cabin is at a premium, so I'm thinking the slide-out pantry will really help the situation.
Michael
The Astroliner
Atomic77
Images: 309
Re: The Astroliner
Postby aggie79 » Mon Feb 06, 2017 1:17 pm
Agreed! :applause: :thumbsup: :applause:
Re: The Astroliner
Postby noseoil » Tue Feb 07, 2017 8:46 am
Michael, nice job on the millwork. It looks like a good design & should give you plenty of storage space. I'm wondering if there will be a top-mounted guide, bracket or tracking "stabilizer" to keep the play out of the unit during travel & when it's being pulled in & out? As tall as it is, there might be a bit of fore & aft play in there somewhere.
137905
noseoil
Images: 670
Re: The Astroliner
Postby Atomic77 » Tue Feb 07, 2017 10:16 am
noseoil wrote:Michael, nice job on the millwork. It looks like a good design & should give you plenty of storage space. I'm wondering if there will be a top-mounted guide, bracket or tracking "stabilizer" to keep the play out of the unit during travel & when it's being pulled in & out? As tall as it is, there might be a bit of fore & aft play in there somewhere.
There are 3 pair of 24" ball bearing, soft close slides that it operates on. According to spec's, 2 pair should suffice. But we're doing 3 pair, one each side on the top, center and bottom of the shelving.
Michael
The Astroliner
Atomic77
Images: 309
Re: The Astroliner
Postby OP827 » Tue Feb 07, 2017 10:56 pm
Michael, that is a fancy design with the slide out pantry, I was not expecting that :thumbsup:
Now what is going to be located above the fridge, a wardrobe space?
You are putting a lot of labor and character into this baby, great work my friend.
OP827
Images: 414
Re: The Astroliner
Postby Atomic77 » Wed Feb 08, 2017 3:51 am
OP827 wrote:Michael, that is a fancy design with the slide out pantry, I was not expecting that
Thank you Oleg! Yes the space above the fridge will be a closet. I'm picking up the cedar for it today. Below the fridge is a drawer. It's surprising how much the slide out pantry will hold!
Michael
The Astroliner
Atomic77
Images: 309
Re: The Astroliner
Postby IndyTom » Wed Feb 08, 2017 9:33 am
:applause: :applause: :applause: :applause:
Gorgeous work!
Never trust a skinny cook
IndyTom
Images: 42
Re: The Astroliner
Postby Atomic77 » Wed Feb 08, 2017 11:06 am
IndyTom wrote::applause: :applause: :applause: :applause:
Gorgeous work!
Thanks Tom!
Michael
The Astroliner
Atomic77
Images: 309
Re: The Astroliner
Postby Atomic77 » Wed Feb 08, 2017 11:09 am
Here's a question for the pro finishers out there. I am spraying most all of the birch with moisture proof lacquer. But I have a couple of areas such as the pantry that I was unable to spray prior to assembly. So I need something quick-drying, brush-able that has a finish that isn't heavy. Thoughts or suggestions?
Michael
The Astroliner
Atomic77
Images: 309
Re: The Astroliner
Postby SCwood » Wed Feb 08, 2017 4:28 pm
Atomic77 wrote:Here's a question for the pro finishers out there. I am spraying most all of the birch with moisture proof lacquer. But I have a couple of areas such as the pantry that I was unable to spray prior to assembly. So I need something quick-drying, brush-able that has a finish that isn't heavy. Thoughts or suggestions?
I brushed spar urethane on all of my birch and it worked pretty well. In the summer heat it took about an hour to dry between coats, and I applied 3 coats, wet sanding with 400 grit between them. About 6 hours after the last coat it was dry enough to handle however you wanted.
SCwood
Re: The Astroliner
Postby Atomic77 » Wed Feb 08, 2017 5:34 pm
Thanks for the tip and for stopping by!
Michael
The Astroliner
Atomic77
Images: 309
Re: The Astroliner
Postby aggie79 » Wed Feb 08, 2017 6:21 pm
Hi Michael,
I'm certainly not in the professional category, but I'd take a look at Emtech EM9300 - https://www.targetcoatings.com/product/emtech-em9300-wb-exterior-polycarbonate-urethane/.
I found out about this product on the forum and used it as a top coat over the epoxy on my tongue box. I applied it with a brush. It flowed well enough to not leave brush marks and somehow it did not run on the vertical surfaces. So far it has been very durable.
Take care,
