Memory foam mattress 6" or 8" please give me your opinions.
Postby TallyTear » Mon Feb 13, 2017 5:05 pm
I am sure there are tons of threads on this. I didn't have much luck finding them. I was planning one 6" memory but then started second guessing maybe I should go 8".
TallyTear
Re: Memory foam mattress 6" or 8" please give me your opinio
Postby CamperBudddy » Mon Feb 13, 2017 7:19 pm
I think it is the density that matters
Sent from my SM-G930T using Tapatalk
CamperBudddy
Postby lrrowe » Mon Feb 13, 2017 7:32 pm
Physical demensions of the trailer matter also. What height works best with the door opening for TD's, are you going to make a fold up bed in CT's and so forth.
Bob
lrrowe
Images: 439
Postby dancam » Mon Feb 13, 2017 8:03 pm
Depends #1 what works in your trailer. My wife spent hours researching foamies for our camping and everyone said denser is better. We got a 3in thick one for on top of an air matress and its so stiff its uncomefortable for me. If it is right on the floor and you kneel all your weight on it your knees arent on the floor. Its like sleeping on a board.
So it depends if you like stiff matresses or soft.
dancam
Postby booyah » Tue Feb 14, 2017 8:11 am
I can say this, I have the 4" spa sensations from walmart.com and it works OK... I kinda wish I'd done the 6"
My build, 5x8 modified benroy "Smiles to go". Started April 2nd 2015, first trip August 2nd 2015.
viewtopic.php?f=50&t=63145
booyah
Postby les45 » Tue Feb 14, 2017 8:20 am
We use the 4" memory foam and it is a good compromise for head room and comfort. It does bottom out when you are on all fours but provides good support when you stretch out. Ours is 1.5" of memory foam and 2.5" of regular firm foam. We found that we like the regular firm foam on top better. I tend to move a lot when I sleep and it was hard to get out of those holes you create in the memory foam when you roll from side to side to back. Also, the memory foam gets really hard when it gets cold.
les45
Images: 605
Postby aggie79 » Tue Feb 14, 2017 9:21 am
Most memory foam mattresses are not 100% memory foam. The top layer - 2" or so - is memory foam and the remainder of the mattress is another type of foam. The 6" mattress may be equal in comfort to the 8" if both have the same thickness of memory foam.
Postby bc toys » Tue Feb 14, 2017 9:22 am
we have the 6'' from Wally world and I like how it sleeps good luck with yours
bc toys
Images: 42
Postby tony.latham » Tue Feb 14, 2017 11:06 am
Glad to hear you're not scrimping on the one-teardrop item that needs to be top-of-the line. Isn't a bed on wheels why we love these things?
I don't think you'd want 8" of straight memory foam. :thinking:
We have a mattress from the foam factory that is 5" of a high density foam with 2" of memory foam on top. It's superb.
Tony :thumbsup:
if one won't do, try two
Postby working on it » Tue Feb 14, 2017 12:06 pm
booyah wrote:I can say this, I have the 4" spa sensations from walmart.com and it works OK... I kinda wish I'd done the 6"
I like a firm mattress...seems to help my back, compared to too soft. We had a Tempurpedic mattress at home for years; my wife loved it, but I did not (I put plywood under my side to try to firm it up). So, when I built the trailer, I tried out various twin mattresses at Ikea, and liked the firmness of this one:
IKEA Sultan Florvag Foam Mattress
ikea twin.GIF (24.79 KiB) Viewed 1409 times
It was just fine for me, but when my wife finally expressed interest in using it (a year later- though she never did actually use it), I bought another to stack on top. I wrapped both in plastic protectors and the bedding fit two as good as one. I have to admit, two is better than one, since I can't bump thru to the floor, now. Another benefit is that two smaller mattresses are easier to insert in, or remove from the door of the trailer.
173193172890148599
working on it
Images: 457
Postby tsyj » Tue Feb 14, 2017 12:14 pm
We use this 5" : https://www.amazon.com/gp/product/B00NX ... UTF8&psc=1
My shoulder will go down to the floor after a while, so I'm going to get a mattress topper to thicken it up a little. If you're not a big guy, or a side sleeper, you'll be ok.
Other than that, it is more comfortable than the much more $$ mattress in my house.
tsyj
Postby Socal Tom » Thu Feb 16, 2017 3:42 pm
I had 4 inch memory foam topper, and it wasn't thick enough, I put 2 inches on top, now it works fine.
Sent from my Lenovo A7600-F using Tapatalk
Socal Tom
Postby Padilen » Thu Feb 16, 2017 6:30 pm
Mine is 7", I can't help you out.
Padilen
Postby Shadow Catcher » Thu Feb 16, 2017 7:49 pm
We have a 5" firm foam, not memory, ans 4" would have been just fine.
Postby ibbuckshot » Sun Feb 26, 2017 10:40 pm
Greeting Y'all,
A friend of ours found out I was going to build a camper and needed to make mattresses or two bunks. He said he had a free answer to our question. He showed up and we unloaded a king size Temper Pedic that measures 10 inches thick. We will get the electric bread knife out and have custom bunk mattresses a la Temper Pedic......... 8)
Have fun,
buckshot
Take time to smell the roses before you end up under them ! ! !
Road rage can be hazardous to your health ! ! !
ibbuckshot
Images: 21
