Floor Frame
Floor Frame
Postby homeroast » Wed Jun 28, 2006 9:30 am
My trailer frame is 2x2x1/8" angle. I'm left with a required floor frame member size of 1 7/8" x 2 1/8". See this pdf to see what I mean.
What's the best way to acheive this size? A lot probably depends on what is available locally, but I'd like to at least have an idea of how I should approach it. Would you laminate a couple of thicknesses or start with an over sized piece and rip it down?
homeroast
Images: 5
Postby Yahnozha » Wed Jun 28, 2006 10:08 am
laminating would probably be less expensive, but i guess it depends on what your gonna attatch to it...
P@ = Pat, yep that simple
Yahnozha
Re: Floor Frame
Postby Miriam C. » Wed Jun 28, 2006 10:21 am
homeroast wrote:My trailer frame is 2x2x1/8" angle. I'm left with a required floor frame member size of 1 7/8" x 2 1/8". See this pdf to see what I mean.
Homeroast,
Homeroast,
I would get 2x6' and cut my framing from it. Remember to cut 2 1/8 wide and use the existing 1 3/4 the other way. Does this mean you are not building a box (top, bottom, inside framing/ insulation)?
Aunti M
Postby homeroast » Wed Jun 28, 2006 11:23 am
I thought a 2x6 was 1.5" thick.
edit: I'm not making a sandwich floor. I'll have cross members to help stiffen the floor and will let my mattress be my insulation. When I camp I usually go to bed with enough Rye coursing thru my blood that it keeps me warm all night :?
homeroast
Images: 5
Postby madjack » Wed Jun 28, 2006 11:35 am
Roasted, you will probably have to laminate something up to get that size unless you have access to a lumber mill and get a larger piece and rip it down....
madjack 8)
