KCStudly wrote:If I had it to do over, now that I have more experience using epoxy on my build, I would have used it more exclusively from the beginning.
Everywhere I used 30NF (sometimes with questionable results and long dry times) I could have used epoxy for the same price.
I try to do all gluing before sealing or finishing, especially for wood and wood glue. Where I did not want glue splotches spoiling the wood finish, I either masked extensively or scrape/sand very well before staining.
QueticoBill wrote:So would you use epoxy for foam to ply, ply to ply, foam to foam, as well as an exterior sub-coating with spar or enamel over?
And CPES as a primer? That seems to be the wood boat regimen.
QueticoBill wrote:OK - TB2 or PLP for your foam to ply adhesive? I'm liking TB2 - for everything - but not sure it will dry through the ply.
Andrew Herrick wrote:QueticoBill wrote:OK - TB2 or PLP for your foam to ply adhesive? I'm liking TB2 - for everything - but not sure it will dry through the ply.
Someone else chime in with a different experience, but I've tried to glue plywood to both extruded and expanded polystyrene foams with TiteBond II, and it certainly did not work.
On the other hand, I've tried different polyurethane glues and foamboard glues, and they worked well. The polyurethane glues required a light misting of the foam; the foamboard glues required several hours of clamping pressure and lots of air drying time.
Sure made me wish I had a 4x8 vacuum bagging system
