rustytoolss wrote:Just wondering about if anyone has had any issues with there foamie when the trailer twists or body flexing. Just wondering if flexing has caused foam to crack. Or does the PMF keep the body rigid enough to help prevent any effects of flexing/twisting ? I have not done any PMF on the foam of my trailer as of yet.
Don L. wrote:I wondered about the twisting aspect too, and mine is a little bigger than yours. It is pretty rigid, no signs of cracks or anything.
It is definitely worth keeping that in mind as you build though. Since mine is so big I used 3/4" ply for the floor, screwed with adhesive to the frame. And all the cabinets that are attached to the floor are fastened with many screws and "L' brackets, then the cabinets are glued and screwed into anchors in the foam. I think all the cabinets, seats and bed framing helps stiffen things up.
Don L. wrote:but not sure I want to stress it needlessly.
Don L. wrote:I think having only 2 wheels and a hitch (3 points) of support on the frame it can't really put any torque or twist on the frame.
My camper has 4 jacks welded to the frame (old car jacks) that stabilize it when camping (or else it would tip backwards badly when unhitched). That makes 4 points of support and if I were to crank one up real high that would put some torque on the frame (which transfers to the walls) , so I try to be aware of that when I am leveling it.
I could test it by supporting the camper on 2 opposing diagonal jacks mostly, but not sure I want to stress it needlessly.
Users browsing this forum: Bing [Bot], DrAlvarez, jgmahoney and 14 guests
