Does anyone have a good video of doing the canvas/TBII install on a camper
GPW wrote:Rusty , if you don’t wash the canvas first it will tend to shrink a bit more during application ... always allow a little extra canvas for shrinkage, either washed or not ... Some feel that washing removes the factory sizing and cleans the fabric for better glue adherence... Your choice ...
We now use 100% TB2 rolled on liberally , then the dry canvas applied and smoothed out ... once dry and seams all glued, we “size" the canvas with 25% TB2 and 75% water , were strength is not needed , the object is the deep encapsulation (waterproofing) of the fabric fibers ( Note: too much glue and the primer doesn’t stick as well ( less “tooth” ) , we proved that to ourselves) ... then Primer and a good outdoor paint ... that works in our hostile climate ...
The reality of the glue is , you don’t need much strength in the glue as the Foam is the weakest element and always fails first in a glue joint .... That’s why the “tight sock” principle works for us , like a a shrink wrap , nothing needed to hold it together , the tight outer skin does all the work ...
rustytoolss wrote:How much coverage (on average) do you think you can get from a gallon of TBII at 100% applied liberally ? Is it best to iron the washed canvas ?
Users browsing this forum: jgmahoney and 6 guests
