QueticoBill wrote:Its for the HT trailer spring hangers and it appears - at least for the rear spring hanger - that its needed because its a slipper spring. Out of about 70 bolts, these 8 (2 - M10X25 - each front and rear spring hangers) are the only carriage head and not yet ready to assume there is no good reason. Both the hangers and frame are punched square...
Aguyfromohio wrote:QueticoBill wrote:Its for the HT trailer spring hangers and it appears - at least for the rear spring hanger - that its needed because its a slipper spring. Out of about 70 bolts, these 8 (2 - M10X25 - each front and rear spring hangers) are the only carriage head and not yet ready to assume there is no good reason. Both the hangers and frame are punched square...
That's good thinking. It cost the manufacturer a dollar extra for each square hole, he did that for some good reason.
McMaster Carr has little square hole punch sets for under fifty bucks here:
https://www.mcmaster.com/#hole-forming-punches/=16r300c
QueticoBill wrote:Aguyfromohio wrote:QueticoBill wrote:Its for the HT trailer spring hangers and it appears - at least for the rear spring hanger - that its needed because its a slipper spring. Out of about 70 bolts, these 8 (2 - M10X25 - each front and rear spring hangers) are the only carriage head and not yet ready to assume there is no good reason. Both the hangers and frame are punched square...
At over $250, I think I'll use a file. Not to mention the smallest is to large at a 1/2". (Seems to be a 13/32" square hole and the square neck on teh carriage bolt seems less than 3/8" - maybe 11/32" or 21/64".)
But thank you. If nothing else, while filing away I'll know I didn't overlook an easier answer.
QueticoBill wrote:In the end I'm beginning to think that just researching, thinking, and posting about this detail may take longer than drilling a hole and having at with a file.
