bobhenry wrote:level the trailer and measure into the ball cup from the ground. This less and inch to and inch and a half should be the optimum towing height measured to the top of the ball. Then I would get a dedicated mount with the correct drop or rise to get me close to that height.
aggie79 wrote:To make things even more confusing you need to factor in the "squat" of the vehicle due to the tongue weight of the trailer. Your reference should be the "loaded" height rather than unloaded height. If you base your drop upon the unloaded height and a level trailer, the drop will be too much causing the trailer to be pitched down at the front.
dancam wrote:Just put 125 pounds in the trunk and measure how much it drops. Probably 1/4inch or less...
QueticoBill wrote:dancam wrote:Just put 125 pounds in the trunk and measure how much it drops. Probably 1/4inch or less...
Wouldn't the car top carrier, canoe on top, and back with seats rear folded (RAV4) filled with gear make a difference? Max payload is 1043 - maybe just load it up with that. I bet I exceed that when I have myself, 4 Scouts, and a lot of gear.....
Good thought - I think I need to build the tear and load it all up.
