Opinion?
Opinion?
Postby IndyTom » Sat Apr 08, 2017 1:46 am
The time has come when I am ready to install the last roof spar, and this will be the one to which my hurricane hinge will be mounted. I am considering just using a nice heavy piece of southern yellow pine, but should I be thinking about using something else?
Never trust a skinny cook
IndyTom
Images: 42
Re: Opinion?
Postby swoody126 » Sat Apr 08, 2017 6:29 am
consider TREATED SYP
that might reduce/retard any effects of potential water intrusion via screw holes caused by using the hatch
sw
swoody126
Re: Opinion?
Postby Woodbutcher » Sat Apr 08, 2017 6:56 am
Consider a harder wood. I also double up the size of that spar.
Woodbutcher
Re: Opinion?
Postby noseoil » Sat Apr 08, 2017 8:03 am
The SYP we used for roof trusses (good, straight grain, tough, stringy, MSR rated at 2,400) was amazing stuff. No need to treat it, just cut to size & use as is. Find the best grain you can (quarter sawn, perhaps?) Pre-drill pilot holes the right size for the screws & bed them in a decent caulk & they will be there for good. SYP is great wood for structural members on a build. Wish I had access to some now.....
http://americansoftwoods.com/species/
137905
noseoil
Images: 669
Re: Opinion?
Postby IndyTom » Mon Apr 10, 2017 9:58 am
I have access to some very good quality SYP as wide construction lumber. I normally cut my own 2X4s and 2X2s from wider lumber because it is so hard to find good lumber these days. I think that last spar will be a SYP 2X4.
IndyTom
Images: 42
Re: Opinion?
Postby KCStudly » Mon Apr 10, 2017 2:21 pm
2x2 is plenty. I used red oak because it was readily available.
Re: Opinion?
Postby kokomoto » Wed Apr 19, 2017 4:03 pm
Ask your supplier if they have a scrap pile. The local hardwood supplier I have used has a stack of "scrap" wood. They found a nice, straight piece of hickory scrap, and cut to 2x2x60" for me. Price...$5. It's very stout, and should serve as a solid anchor my hatch hinge, and might outlive the rest of the TD. I'll coat it with epoxy varnish to keep it dry.
kokomoto
Re: Opinion?
Postby mikeschn » Wed Apr 19, 2017 5:14 pm
Unless your hatch is unusually heavy, I think a doubled up pine spar should do just fine. I've done that many time and never had a problem.
If you're looking for an excuse to use white oak or something else that is weather resistant and strong, go ahead... that 1 unique spar won't add that much weight!
Images: 479
Re: Opinion?
Postby SSTear » Tue May 02, 2017 2:51 pm
I doubled that spar on my build and glued a 2x2x1/8 Alum angle to it to stiffen the galley hatch mounting. My galley opening is 56w X 56h which is pretty big. No issues.
SSTear
Images: 43
Re: Opinion?
Postby GuitarPhotog » Tue May 02, 2017 5:29 pm
Pressure treatment does not prevent wet/dry rot. It prevents insect damage and is usually used when in contact with the ground. As the others said, use a SYP 2X4 no treatment.
<Chas>
:beer:
GuitarPhotog
Images: 55
Re: Opinion?
Postby Kaz » Tue May 02, 2017 5:38 pm
I went with doubled up maple. wanted a hard wood for holding screws.129738
Kaz
Kaz
Images: 122
