I've been using two glues PL Premium & Gorilla glue on my build. My foam is 2" XPS.
I have a question about gluing my walls to the plywood floor. Since GG pushes &expands while drying. What is the best way to attach the wall so they do not move (in and out' & up and down) ? How do I keep them from been pushed out of place ?
Or would I be better off using the PL P glue, since it does not create shifting material ???
Also is there a good way to add some weight to the top edge of the wall (while gluing) to help push the wall down. To aid in the gluing process ?
Any pictures , advise, links, or secrets (or secret prayers) you would like to share... would be welcome
