Chesapeake Light Craft Teardrop Trailer
Re: Chesapeake Light Craft Teardrop Trailer
Postby KingAirNeal » Sun Mar 26, 2017 10:01 pm
That thing looks SO COOL!!!! If one was to say.... chose to not clear coat it, and i stead make it look like a flying saucer.... just sayin...
KingAirNeal
Postby friz » Sun Mar 26, 2017 11:36 pm
It a completely different aesthetic in paint.
Sent from my Altair 8800 using Tapatalk
The "Sin Bin"
150133
friz
Images: 6
Postby KingAirNeal » Mon Mar 27, 2017 12:01 am
Yes it is. I think the clear coat look is stunning. Always my first choice. My baltic birch was so bland, no character to it, no reason to clear it. But yours... Wow. Just... Wow. You are an artist. Very nicely done.
KingAirNeal
Postby Alan_H » Mon Mar 27, 2017 11:12 am
Did you get the galley package to go with your CLC Teardrop?
Alan_H
Postby friz » Mon Mar 27, 2017 1:31 pm
Alan_H wrote:Did you get the galley package to go with your CLC Teardrop?
No, I felt it took up a lot of space in the galley. My battery is going under the camper leaving the entire space as storage.
The "Sin Bin"
150133
friz
Images: 6
Postby friz » Sat Apr 01, 2017 7:07 pm
Applied what should be the last coat of epoxy to the insides of the doors and hatch. Also the final coats to the inside of the transom and the floor.
I started working on the trailer, cutting the side rails to the proper length to fit the camper shell.
The "Sin Bin"
150133
friz
Images: 6
Postby friz » Sun Apr 02, 2017 11:24 pm
The "Sin Bin"
150133
friz
Images: 6
Postby KingAirNeal » Sun Apr 02, 2017 11:28 pm
Thats damn fine work right there... damn fine.
Well done.
KingAirNeal
Postby friz » Mon Apr 10, 2017 11:07 am
Again, I sand....ImageImageImage
Sent from my SM-G900V using Tapatalk
The "Sin Bin"
150133
friz
Images: 6
Postby aggie79 » Mon Apr 10, 2017 12:11 pm
:thumbsup: :applause: :thumbsup: Very nice - as usual!
What are your thoughts on the NT aluminum trailer?
Postby working on it » Mon Apr 10, 2017 12:19 pm
I just have to comment on your out-of-this-world craftmanship. It's A-OK.
Martian spacecraft meets Friz's Chesapeake Light Craft.png (529.77 KiB) Viewed 3247 times
173193172890148599
working on it
Images: 457
Postby friz » Mon Apr 10, 2017 2:00 pm
aggie79 wrote::thumbsup: :applause: :thumbsup: Very nice - as usual!
Easy to assemble and modify because of the frame material. A good value. I do recommend a powered ratchet of some sort to assemble. A ton of hardware to wrench. The only issue i found was a hub dust cover that doesn't fit tightly. I have yet to complain to Northern Tool.
The "Sin Bin"
150133
friz
Images: 6
Postby friz » Sat Apr 15, 2017 8:05 pm
Cut some holes for vents and fabricated a battery mount from left over trailer aluminum. I still have enough material to make another one if I decide to double the capacity.ImageImageImageImageImageImageImageImage
The "Sin Bin"
150133
friz
Images: 6
Postby AzAv8r » Sat Apr 15, 2017 9:22 pm
Interesting (and very efficient) battery mount, if I interpret correctly. The salient points of my understanding are:
- battery carried on beefy aluminum angles
- allthread cross-ties clamp the angles against the battery
- allthread hangers clamp the battery against the underside of the trailer floor
- the allthread hangers attach to T-nuts (?) installed on the floor from inside the trailer
- the battery is positioned in the center of the trailer laterally, and just behind the axle
- the battery is oriented on it's nominal "side", such that the terminals are on the vertical battery face towards the back of the trailer, close to the floor
- No extra material is used for the battery mount beyond the angles, the allthread, the T-Nuts (or alternate), and the battery itself.
Is this a correct interpretation? What size allthread? Maybe #10 for the cross-ties and 1/4" for the hangers?
Thanks for sharing!
AzAv8r
Images: 6
Postby friz » Sat Apr 15, 2017 10:00 pm
AzAv8r wrote:Interesting (and very efficient) battery mount, if I interpret correctly. The salient points of my understanding are:
Thanks for sharing!
Pretty much correct. The only thing incorrect is I used 3/8 x 8 inch carriage bolts through the floor. The allthread clamping the brackets together is 3/16 or #10.
The "Sin Bin"
150133
friz
Images: 6
