6X12 SS&S
Re: 6X12 SS&S
Postby Iconfabul8 » Tue May 02, 2017 1:18 am
I need to put another hole in the wall. Seems like that is a continual theme here on the forum.
Screwed some boards to the wall as a rotozip guide.
Moved the upright guide to the right side and finished cutting the 3/8" interior osb. "NOTE" Should have cut the right side first.
When following a guide, cutting clockwise works best.
Cleaned out some insulation and cut a notch out so that my dog dish would be in the right position. DOG DISH? Whaaat? :crazy:
Made this board as a backup/cutting guide/spacer. Screwed a 1/4" piece of mdf on to make it exactly 1"
Slid it nicely into place.
Screwed the dog dish to a board. Used a 3 1/2" hole saw in the drill press and after a lot of noise I had a hole.
Even thin stainless is not fun to cut.
The hole needed to be just a little bigger than 3 1/2" so I rounded off the edge of this aluminum bar to use as an anvil,
then rounded the edge of the hole with a ball peen hammer.
Gooped it up with silicone and screwed it in the hole. Sorry I didn't get a pic of the hole in the outside skin,
I cut it from the inside with the rotozip.
I needed a line that sloped 3 deg up from the top of the hole. So I printed one and extended it with the tape you see.
And that is how I am venting my hot water heater!! :D The pipe needed to slope 3 deg so rainwater doesn't run into the heater.
https://www.aquahstore.com/catalog/prod ... l3k1jmf177
View from the outside. The dog dish helped keep it from sticking out too far.
This particular tankless WH sucks outside air for combustion.
Air is sucked in through the outside pipe and exhaust comes out the inside pipe.
Iconfabul8
Images: 14
Re: 6X12 SS&S
Postby Philip » Tue May 02, 2017 7:46 am
:applause:
Nice clean install.
Philip
Images: 323
Re: 6X12 SS&S
Postby aggie79 » Tue May 02, 2017 8:01 am
Philip wrote::applause:
Nice clean install.
Agree! :thumbsup: :thumbsup: :thumbsup:
Re: 6X12 SS&S
Postby flboy » Tue May 02, 2017 7:32 pm
You do great work! Very nice. :thumbsup: :thumbsup: That almost looks like some sort of anti-aircraft gun barrel. :thinking:
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Re: 6X12 SS&S
Postby working on it » Tue May 02, 2017 7:49 pm
Nice, but a little intimidating.
port-heater or mg-.jpg (61.11 KiB) Viewed 4700 times
173193172890148599
working on it
Images: 457
Re: 6X12 SS&S
Postby McDave » Wed May 03, 2017 11:23 am
Very nice work. :applause:
McDave
McDave
Images: 412
Re: 6X12 SS&S
Postby Iconfabul8 » Wed May 03, 2017 8:46 pm
Thanks Guys! Yeah, I was thinking I would probably get a few artillery comments. Haha
Iconfabul8
Images: 14
Re: 6X12 SS&S
Postby Iconfabul8 » Wed Jun 07, 2017 11:44 pm
It is a small step forward, But a step forward nonetheless. Installed and painted the bathroom chair rail.
Iconfabul8
Images: 14
Re: 6X12 SS&S
Postby McDave » Thu Jun 08, 2017 4:20 am
:thumbsup: ;) :D
McDave
Images: 412
Re: 6X12 SS&S
Postby flboy » Thu Jun 08, 2017 7:03 am
That is sharp! Nice job!
Don (Flboy)
flboy
Images: 378
Re: 6X12 SS&S
Postby Iconfabul8 » Sat Jun 10, 2017 2:23 am
Kind of excited. My Seaflo shower sump showed up today. Ive thought long and hard about my shower drain geometry and I just don't want to lower the gray water tank that low. Sooo, I think this is going to be a great solution.
http://www.ebay.com/itm/281949986568?_t ... EBIDX%3AIT
Iconfabul8
Images: 14
Re: 6X12 SS&S
Postby flboy » Sat Jun 10, 2017 7:01 am
Hi. That pump is interesting. How and where does that get mounted? Is your gray water tank inside the trailer?
Don (Flboy)
flboy
Images: 378
Re: 6X12 SS&S
Postby Iconfabul8 » Sat Jun 10, 2017 12:51 pm
flboy wrote:Hi. That pump is interesting. How and where does that get mounted? Is your gray water tank inside the trailer?
I suppose you could put the tank just about anywhere, but I am going to put it underneath up against the floor. As for the sump, it is designed for boats. It needs to have access to the top, so I will have to figure out a way to swing or pull it out from under the trailer.
Iconfabul8
Images: 14
Re: 6X12 SS&S
Postby Iconfabul8 » Thu Jun 15, 2017 12:31 am
The valves are mounted, YAY !!!!!
View from underneath. Had originally planned to attach to frame with 1/4" sheet metal screws, however,
the frame is pretty hard stuff and stripped the screws. Ended up tapping the holes.
Iconfabul8
Images: 14
6X12 SS&S
Postby Padilen » Thu Jun 15, 2017 6:19 am
Are you left handed? I noticed your dump release handle is left hand pull. Or do you just want to be a little further away when you pull that.
I like how you mounted it. I used plumbers helper as a temp- still haven't finished it.
Padilen
