I know there must be some use for bubble-wrap in my project..
Kris
tonyj wrote:Now, how could I put to use a self-built vacuum pump? hmm . . .
DrewKaree wrote:If I'm understanding all this correctly, wouldn't you be able to take a 2x4 (or 2x6) and make a caul, then slide a piece of either angle iron or use the trailer itself as a base to clamp the edges of the caul to?
asianflava wrote:In my experience, the problem I ran into was poor compression along the edges. That was more my fault than anything. I was afraid the "clamps" would get glued to the panels by the epoxy that oozed out.
alaska teardrop wrote:
Had to look that word up. Caul = The large fatty omentum covering the intestines. Only in Wisconsin.![]()
