Metal/wood adhesive?
Postby Jfox1095 » Sun May 14, 2017 10:42 pm
So I'm working out the kinks in my current design at the moment, and I came across an issue I am not familiar enough with to be comfortable so I came to ask you guys.
I am building with a metal frame, and I was wondering what kind of glue or sealant would I use to seal my wood panels to my frame. On my last build I used all wood, which allowed me to just use epoxy and paint.
My plan currently is to use 2" square tubing for the main portions of the frame and then laying smaller square tubing the thickness of my insulation centered on the 2". The plan is to have the thickness of my inner and outer wood panel of the wall plus the insulation match the 2" giving the metal framed wood appearance.
My question is what do I use to seal up where I attach my wood to my metal.
Jfox1095
Re: Metal/wood adhesive?
Postby John61CT » Sun May 14, 2017 11:29 pm
Gorilla, polyurethane glue like PL Premium, many epoxies like Loctite, West's Six10
John61CT
Postby dales133 » Mon May 15, 2017 1:49 am
Sikaflex 252 assembly adhesive
Sent from my SM-N910G using Tapatalk
dales133
Postby rabtmac » Thu May 18, 2017 5:16 pm
http://www.ct1ltd.com/
Not sure if this is available in the states but I can honestly say once you use ''ct1'' on any of your builds or indeed anywhere you will never use anything else ever again
It's claims seem far fetched if you've never come across it before but they are genuine
Everything will be alright in the end, if its not then it isn't the end yet.
rabtmac
Re: I see ya baby, shaking that hatch
Postby ChefConroy » Sat May 20, 2017 7:40 pm
Gorilla glue. Holy crap. The stuff is amazing. Get it in caulking gun form at the Homeless Despot or Rob Lowes.
jondbar628 wrote:Big ol' hatch. What's the weight?
Uh, a lot. 150-200? Took three of us to get it on there.
Haven't gotten any pistons or springs on it yet, but I can still hulk it open by myself.
John61CT wrote:Gorilla, polyurethane glue like PL Premium, many epoxies like Loctite, West's Six10
Sent from my LG-H820 using Tapatalk
ChefConroy
Postby John61CT » Sat May 20, 2017 7:55 pm
ChefConroy wrote:Gorilla glue. Holy crap. The stuff is amazing. Get it in caulking gun form at the Homeless Despot or Rob Lowes.
Only downside is the messy 3x expansion. Can be handy with large gaps to fill, but spillage needs to be handled quickly, warm soapy rag as it's foaming, before it starts to set.
Acetone is the only solvent afterwards, and that can be very nasty on the surrounding surfaces, best avoided completely if possible.
John61CT
Postby working on it » Sat May 20, 2017 8:28 pm
I previously used Liquid Nails to join wood or plastic to metal (on the underside of trunk-mounted fuel cells), to reduce vibration loosening them from the straps. but, after awhile, it proved not flexible enough. When building my TTT, I used PL Premium on all seams, inside and out, of my superstructure, and where the frame and cabin met. Unless I remove the cabin, I'll never know how well it joined wood and steel together, so it's a moot point. But, when I joined my metal window frames to the cabin, I used OSI Quad sealant, and it is still flexible to this day, after 5 years of Texas heat. I keep a tube handy, in case I need a quick seal, even on my house. Good stuff.
173193172890148599
working on it
Images: 457
