7x16 V-nose conversion - Tennessee
Re: 7x16 V-nose conversion - Tennessee
Postby ffemtp » Thu Apr 27, 2017 8:27 am
Started building the cabinets.
ffemtp
Postby MyYota85 » Sun Apr 30, 2017 8:41 pm
Looking good what's the goal with it? Going to add a bathroom? Kitchen?bed? Etc..Those rims are awesome!! Good luck
MyYota85
Postby flboy » Mon May 01, 2017 6:26 am
Wow. Very nice looking trailer. You putting in a bathroom, shower, and etc.?
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby ffemtp » Mon May 01, 2017 7:34 am
I finally added the refrigerator and countertop and cut the upper and lower shelves to fill the V-nose behind the countertop and the base of the upper cabinets. All electrical is completed. I still have to install and plumb the sink. Because of limited room and the need to use this as a toy hauler, I decided not to install a shower and toilet. I plumbed a pressurized water outlet to the outside that I can connect my instant water heater to and have an outdoor shower. I also have a portable toilet with a 2-gallon reservoir.
ffemtp
Postby McDave » Mon May 01, 2017 12:04 pm
You are really moving on that build. Looks good. Keep that stuff up.
McDave
McDave
Images: 412
Postby firemansd19 » Mon May 01, 2017 2:40 pm
I really like that switch panel. Gimme the low down. Where did u get it and what do they cost.
firemansd19
Postby ffemtp » Mon May 01, 2017 4:46 pm
The switch bank I purchased is this one: http://amzn.to/2ppcZiA I like that it has two wires to positive, two wires to negative, and then you use a female spade clip to connect your equipment to the preferred switch. That's it and your done! It uses a 10A fuse to power the panel so plan to add an in-line fuse on whatever you connect. It also has a volt-meter, USB output and 12V output. I have wired it so that it is after my main battery switch. BTW, it had a lot of good reviews and I have been happy with it thus far.
ffemtp
Postby ffemtp » Mon May 08, 2017 9:00 am
More work...
ffemtp
Postby ffemtp » Sun May 14, 2017 6:56 am
And almost done!
ffemtp
Postby ffemtp » Mon May 15, 2017 11:40 am
Floor is in!
ffemtp
Postby flboy » Mon May 15, 2017 1:03 pm
Very nice! Looks great!
Don (Flboy)
flboy
Images: 378
Postby ffemtp » Mon May 15, 2017 1:38 pm
Bed in place.
ffemtp
Postby firemansd19 » Mon May 15, 2017 8:03 pm
ffemtp wrote:Floor is in!
What's the scoop on that flooring. I have found something similar at home depot. This is exactly what I want to put in mine.
firemansd19
Postby ffemtp » Tue May 16, 2017 7:02 am
[quote="firemansd19"][quote="ffemtp"]Floor is in!
That is where I got mine. I paid about $200 shipped for the 7.5'x16' piece. It went down very easily using the recommended adhesive. I am still wondering how it will "stain" when I drive the toys inside. The warning label commented how tires will stain it. But, it is a toy hauler and not a showpiece!
ffemtp
Postby McDave » Tue May 16, 2017 7:17 am
Ya Baby! Knocked that out in a hurry. Nice work. I have similar flooring, no problem with Harley tires.
Way to go! You're gonna love it.
Congratulations,
McDave
McDave
Images: 412
