Rusty, did you try running your saw blade backwards …
rustytoolss wrote:Had I known more about doing kerfs. I would have bought some 1" xps for one section of my roof (2pcs stacked). But not knowing I bought all my foam in 2" thick. I will need to make a 18" inner radius 90 degree curve. I'm going to try this with a piece of scrap 2" foam first. To see how this go. If I don't feel like it's going to work out well. I may have to make my radius in long small sections. Can anyone tell me the spacing for kerfs / and depth of cuts for 2' foam / and number of cuts needed?
Another question I have is. I bought a fine tooth blade for my 10" table saw. Thinking it would give me better cuts in the foam. But I have problems when I cut the foam. The saw will grab the foam , almost like a kick back thing. So I have been using my circ saw instead . I don't get any kick backs with the circ saw.The circ saw has an old general use blade.
Could the fine tooth blade on the table saw be creating my problems ? I actually cleaned off all the foam residew off the side surfaces of the table saw blade thinking that would help prevent the grabbing problem. But it made no difference.
lthomas987 wrote:rustytoolss wrote:Had I known more about doing kerfs. I would have bought some 1" xps for one section of my roof (2pcs stacked). But not knowing I bought all my foam in 2" thick. I will need to make a 18" inner radius 90 degree curve. I'm going to try this with a piece of scrap 2" foam first. To see how this go. If I don't feel like it's going to work out well. I may have to make my radius in long small sections. Can anyone tell me the spacing for kerfs / and depth of cuts for 2' foam / and number of cuts needed?
I got a 12" radius in 2" foam. Using a course blade in my table saw. Cuts 1.5" deep.
So you had no problem bending a radius on 2" foam ?
lthomas987 wrote:I have a spreadsheet that does all the math for you if you want to give it a try I could share it. It's not well documented at this point but I would be glad to clean it up some next week.
https://docs.google.com/spreadsheets/d/ ... Hs/pubhtml
rustytoolss wrote:lthomas987 wrote:I have a spreadsheet that does all the math for you if you want to give it a try I could share it. It's not well documented at this point but I would be glad to clean it up some next week.
I found your spreadsheet for doing Kerfs. But I cant seem to make it work. I'm doing a 18" inside radius (90 degrees) in 2" foam. And like you said before cutting 1.5" deep.
How can I make the spreadsheet work ?
lthomas987 wrote:https://docs.google.com/spreadsheets/d/1Kk7c9hEz1XWNd5RT-SXk2GimpYZOMOlkoKAXUTULIHs/edit?usp=sharing
Try this link I think the other one was the direct link for me.
rustytoolss wrote:lthomas987 wrote:https://docs.google.com/spreadsheets/d/1Kk7c9hEz1XWNd5RT-SXk2GimpYZOMOlkoKAXUTULIHs/edit?usp=sharing
I just made a test piece of 2" foam using your spreadsheet information. Works like a charm. Very happy
. I will start on the actual roof piece on Monday. Thanks
chartle wrote:steveonzakon wrote:Now on to my question/suggestion. Would a solder gun or wood burning gun (the hand tool you use to burn letters into wood) run at a good temperature to kerf foam?
Both seem to run at round 800 - 900 deg F, or thereabouts from what I've found on the internet.
If that is too hot, you can buy or build regulators to adjust the heat output. http://pcbheaven.com/projectpages/Homem ... ic=worklog
I haven't seen a recommended heat for burning through foam without setting things on fire, if thats even possible.
The issue is not how hot it can get but how quickly it can recover as it cuts. You would need at a minimum a pistol grip soldering gun of around 180 watts or this.
http://www.harborfreight.com/130-watt-h ... 60313.html
