mounting spare tire on outside of rear ramp
Postby yycwrangler » Sun May 21, 2017 3:28 pm
Tried to get a hold of Coventry kid who has done this but he is unavailable at the moment. has anyone else mounted their spare tire to the lower portion of their ramp (outside)..If so, care to share any pics as I would love to do the same
Cheers
Al
yycwrangler
Re: mounting spare tire on outside of rear ramp
Postby CoventryKid » Sun May 21, 2017 5:39 pm
Al:
Sorry, on the road right now in AZ - Meteor Crater east of Flagstaff.
Check ebay for "Load locker" spare tire holder. This mount came with my trailer when I bought it in 2014 -spare mounted inside.
I asked around to see if 1 mount was enough for outside mount (if spare fell off inside, no biggie, but outside....) So I bought another and mounted them 1 on top of the other with 1 stop screw at the bottom. That way, with a little bit of effort I had 2 mounting points. This has worked well for over 2 years.
Hope this is what you were looking for.
Doug
Vancouver Island, BC
GMC Savana Explorer Limited SE hightop conversion van
NEO NAVR 7x16 V-nose aluminum trailer now a comfortable travel trailer
Build: http://www.tusker-international.com/1-trlr-build.html
CoventryKid
Images: 130
Postby working on it » Sun May 21, 2017 7:32 pm
  • Here's a simple alternative, if you want to make your own.
    load locker vs carriage bolt for enclosed trailer spare tire mount.jpg (99.33 KiB) Viewed 2919 times
    since spares are heavy, a bottom rest is advised
173193172890148599
working on it
Images: 457
Postby hankaye » Sun May 21, 2017 8:28 pm
yycwrangler, Howdy;
The mounting bracket that came with my trailer, still to figure out where it will call home,
is like this one only for 6 hole pattern.
http://parts.trailersplus.com/tire-moun ... t-pattern/
I'm sure that you could make one yourself for less cost if you want. Mount the flat strap
on the inside and ensure the bolts are long enough to mount the spare on it. I would also
solidify the area for mounting with something like a piece of 2X4 or something like that to
keep the sheetmetal from bearing the weight on the outside. Make strong ... like rock ;)
hank
PS. you've got this running with a duplicate thread.
hankaye
Postby McDave » Sun May 21, 2017 9:23 pm
Go back to Adam's (Jiffypop207) build. His entire project was great but he did a nice job on the spare mounting on ramp.
Re: New to me 7x14 CT conversion
Postby Jiffypop207 ยป Tue Aug 19, 2014 5:16 am
viewtopic.php?f=42&t=60663&start=15
McDave
McDave
Images: 412
Postby yycwrangler » Mon May 22, 2017 9:51 pm
Thanks Guys..
This is the unit I got with my trailer..The frame is aluminum..Down the centre are several holes which I would attach via carriage bolts or similar to a park of the ramp 1" tubing frame. I only see the one bolt to hold the tire on but Im sure I could add a second..Thoughts... or should I look for something more solid
Al
IMG_2012%20copy copy.jpg (207.55 KiB) Viewed 2670 times
yycwrangler
Postby CoventryKid » Tue May 23, 2017 3:43 pm
Al:
Can't quite make out your picture, but as I suggested, I thought 1 bolt to hold a spare on was not enough, so I bought a second unit so my spare is mounted with 2 bolts.
Others have suggested other ways to accomplish the same thing at lower cost.
With the spare at the back, it's out of the way and it does not affect the operation of the ramp.
Hope this helps!
Doug
CoventryKid
Images: 130
Postby yycwrangler » Tue May 23, 2017 4:25 pm
Thanks Doug
For some reason my pics always seem to come out larger..If you go on the pic and roll your mouse it will show you the rest of the pic..Sorry about that
yycwrangler
Postby McDave » Wed May 24, 2017 1:29 pm
hankaye wrote:yycwrangler, Howdy;
hank
@ hank,
If I'm reading that right, they intend for this to bolted to a wall stud in the vertical axis, correct?
McDave
McDave
Images: 412
Postby hankaye » Wed May 24, 2017 4:52 pm
Howdy;
hank
@ hank,
McDave
Generally I'd reckon so, however with support I don't see why it couldn't be done horizontally.
The most important part for an exterior mount would be to ensure some support behind and
against the sheetmetal. Keep from wallowing out the holes.
hank
hankaye
