faust_21 wrote:How did you mount your etrack? Did you have to weld in supports? Really wanting to do the same, but not sure how to mount them.
Look at post #31 for more pics.
In the pics u can see the pieces of horizontal tubing that is welded in place. This are 1" x 1 1/2" rectangle tubing, 14 gauge. It's a little overkill, next time I will use 11 gauge. My bed frame will be built to hold a queen size mattress (60" wide). The Etrac is about 12" in from the edge. There was no scientific formula on doin that. Just seemed like a good place to do it.
Rear Etrac has 6 screws holding it in (1 1/2", #14 self tapping screws)
Front Etrac has a few extra because I used the verticals support beams on the front side.
Hope this helps you out.
