Sent from my SM-G930V using Tapatalk
colt45 wrote:I was going to go with a 20 footer but need to haul a side by side and 2 wheelers, add in the wide and 3 kids and 24' gets small fast. Glad i didnt go bigger tho.
Redneck Packrat wrote:Good looking setup, fast work putting it together! Looks like it's gonna be fun, which means it's gonna get used a lot![]()
Now....colt45 wrote:I was going to go with a 20 footer but need to haul a side by side and 2 wheelers, add in the wide and 3 kids and 24' gets small fast. Glad i didnt go bigger tho.
I sure hope that was a typo, or you'll be in a pup tent gazing wistfully at the new mobile mansion!
rebar wrote:Why anyone would want fendered trailer wheels? Cheaper to build I guess.
Padilen wrote:As Don has said width and height more wind resistance. Fenders to not intrude inside, changing flats easier.
Custom order size and style you want. Why do a 4" lift when you can order with a straight axle & over or under slung.
My CTC is 7x12 toy hauler plenty of room for me and dog. But mines a camper not an RV.
flboy wrote:Anyone know that, if you get the extra width, that the licensing (weight class) and etc. changes.. I have noticed that sometimes builders will put 1,900 lbs. weight on the sticker for various similar lengths... but I didn't see that on the wider versions? I found that odd as my original 14" CTC and this 18" CTC had the same weight on the sticker. And if you looked around, they were very careful not to get to 2,000 lbs. unless it was just obvious... is it just rounding of numbers or is there something a 2,000 lbs trailer weight triggers?
