John61CT wrote:Old school: just toss the fine grounds in the cup with boiling water, stir a few times, let it stew, settle and cool.
Drink from the top, stop when you get those lovely dregs in your teeth.
There you go!
![Thumbs Up :thumbsup:](./images/smilies/econ_thumbsup.gif)
flboy wrote:Congratulations on a very nice looking trailer.![]()
I wouldn't expect much better gas mileage unless you get a Diesel. My guess is you will get about the same MPG fully loaded (unless in the hills) . Most of the energy is spent pulling that mass through the air which does not change when loaded and these newer trucks are optimized for gas mileage when empty and stock. I'll get anywhere between 18-21 MPG with my F150 4WD (302V8) depending on my speed and winds, but when you drop the trailer on... mileage goes down 40 to 50%. Loaded or not seems to make little difference (it is flat here). That is normal from what I understand.
You can improve the handling behind the truck with a sway bar and load balancing hitch (will make it easier for you), but how you balance the build/load will make the biggest difference.I wouldn't be too concerned yet. The empty trailer seemed to pull worse for me . They are relatively light when loaded and the wind and passing trucks seem to push them around a lot more. You will get use to it quick and it will be easier to keep it all in one lane.
It is kinda late for you now, but I had an extended tongue put on my trailer to make the backing up easier and it also prevents denting up the front with the bumper if you back up too sharp. I learned that from my first build. You will remember that if you ever do this again.
I look forward to your build!![]()
Padilen wrote:Unless you go diesel that MPG is about normal for a pickup. Don't believe all the hype about great towing MPG.
