jr9744 wrote:@fftemtp The cabinets look good. I like your counter too. I'm also considering getting that same gray floor you have. I was originally thinking about wood planks, but I read that if water gets under them or on them that it is hard to fix and your floor will get damaged. Don't really want that.
Appreciate everyone posting their cabinets. Just looking at them and knowing others tackled this job with success is making me more confident by the day.
@Jscwerve I would buy some if the price was right too. Curious where your from, cause up here in Maryland, everything seems to be expensive.
I was considering these on Craiglist for 500 which is a whole kitchen plus counter and sink. https://baltimore.craigslist.org/mat/6142723842.html But I do want to maximize my space and learn the new skills which is what I'm more after.
Habitat for Humanity keeps on coming up. So i'm going to make sure I pass by there once I get into the finishing parts.
aggie79 wrote:jr9744 wrote:@fftemtp The cabinets look good. I like your counter too. I'm also considering getting that same gray floor you have. I was originally thinking about wood planks, but I read that if water gets under them or on them that it is hard to fix and your floor will get damaged. Don't really want that.
A couple of additional thoughts on pre-made cabinets:
1. If the cabinets are built with "cases" - that is plywood or particle board sides - it is not that hard to cut down or reduce the depth of the cabinet for cabinets with doors only (without drawers.) Drawers could be cut down too but that is a lot more work plus you would need to purchase new drawer slides.
2. Even if you don't use the cabinet cases and face frames, if you can get the cabinets cheap enough and if the doors are sized for what you are building, use the doors from the purchased cabinets and build new face frames and cases/side rails.
