GuitarPhotog wrote:When you were "chasing leaks" what were you repairing them with? When the fan seal leaked, did you remove it, remove the old caulking, and then replace the caulking/sealant with a quality polyurethane material? Or did you just squirt some more caulk into the hole hoping it would seal this time?
My $0.02 worth
<Chas>
Jscwerve wrote:This is one of the reasons I bought a rivetless cargo trailer for my conversion. Also why I went with the doomed roof instead of flat.
It may leak one day, but I try to eliminate the possibility as much as I am able.
flboy wrote:-snip-
So, you can get a leak and not be destroyed with a CTC... The key is to check everything about twice a year and replace caulk where needed. I can't imagine leaks along anything I installed with all the dicor tape underneath, silicone , etc.. I checked it all with a pressure sprayer before I put the insulation and inside panels back on.
However, nothing lasts forever... everything requires some maintenance.. take care of your stuff and it takes care of you.![]()
rebar wrote:Jscwerve wrote:This is one of the reasons I bought a rivetless cargo trailer for my conversion. Also why I went with the doomed roof instead of flat.
Thanks Jscwerve.. What brand trailer, and is the doomed roof one piece, or seams every 4' ? The featherlite had a one piece, but had low spots where water pooled on the caulked seam.
McDave wrote:Well see, there's your problem. you bought a trailer with a doomed roof. What the heck did ya think was gonna happen? Geez..Kids these days.
McDave
aggie79 wrote:Hi Pinstriper,
I think I remember you from the old LivinLite owners forum before Thor took over and shut the forum down. The "old" CampLite products were really good (other than a few minor buy fixable QC issues.) I wished that I had had the means to purchase a CampLite "pre-Thor", but hope someday to try to build something similar with an ATC, FeatherLite, or Sundowner all-aluminum trailer as a base.
Take care,
Users browsing this forum: Google [Bot] and 1 guest
