Do you have the dreaded, screw head nails?!. If that's what they are I'd probably drill head off and pry boards off the remove the nail.
Padilen wrote:Do you have the dreaded, screw head nails?!. If that's what they are I'd probably drill head off and pry boards off the remove the nail.
flboy wrote:jr9744 wrote:The good news for today is that my trailer is ready!!! Looks like i'll be driving down to GA on Saturday so I can pick it up Monday morning to drive it back to MD.
Now I'm starting to get super excited...
Yay... I am exited for you! That is great!
On the coffee... I raised a bunch of coffee snobs (didn't get it from me)... Starbucks or their elaborate home brews only for them (wife and daughters). The have the electric frothers and etc. for making the designer drinks and etc.![]()
They go to a Coffee house to get their custom ordered roast and grind the beans at home.. I guess they could have worse vices...
My son is almost as bad.. he's somewhere on the spectrum between my girls and I.. I can go fancy or drink Waffle House coffee as long as it has caffeine.
French presses really do brew a nice cup. The pour over drip does nice also as it does not use paper so all of the flavor and oils aren't absorbed. My girls would be proud of me.![]()
Ditto's on the Fench Press cleaning hassle... The pour over is easier to clean for sure..
jr9744 wrote:Padilen wrote:Do you have the dreaded, screw head nails?!. If that's what they are I'd probably drill head off and pry boards off the remove the nail.
How would I know that? I put one pic of the screw in good shape, do you think is the screw you mention?
hankaye wrote:jr9744, Howdy;
I've had luck by dipping a damp screwdriver tip in some Comet or Ajax. It improves the 'bite' in the screw head. Also,
are you using a Prince & Reed or Phillips of the proper size? If you still fail to extract any of the screws then I'd think
that they most likely are the screw-headed nails and I'd just drill off the heads and pry the wall panels off.
hank
Forget the frustration of trying to drill, go get a good nail puller aka cat's paw.
https://en.wikipedia.org/wiki/Cat%27s_paw_(nail_puller)
With each smack of the hammer you can feel the tension leaving and your
family will be happy to see you after you're done. Rather then the grumpy Gus
that will show up after attempting the drilling.
hank
Iconfabul8 wrote:You could find a very small thin walled hole saw and cut around the nail. Sort of like I did on my ceiling staples.
