dirtsailor2003 wrote:Nice build! Looking forward to seeing it all ready to go.
Thanks! I'm hoping to have it ready to roll by Independence Day. The galley will get finishing touches after we use it a few times.
ryan112ryan wrote:Curious you've mentioned you deviated from the shop manual some and in the end it was more difficult, what specifically?
kokomoto wrote:ryan112ryan wrote:Curious you've mentioned you deviated from the shop manual some and in the end it was more difficult, what specifically?
On the wall I didn't make the skeleton large enough to extend all the way out to the edge of the wall pattern in some places. I'm not sure what I was thinking at the time, but if I had though far enough ahead, I would have realized why this is a bad idea.It left some flat spots on the 1x4s where the skeleton was too small instead of a nice curve matching the outline of the teardrop pattern. If left alone, the 1 5/8" cut around the roof that is later used as blocking between the roof spars would not be flush with the outer roof plywood in some places. I patched it up by cutting some narrow strips of 1x4 and gluing them in place. I then had to go back and trim them down to the proper curve with the pattern router bit. It was a lot of extra work that could have been easily avoided. I hope you can picture what I'm trying to describe. Not sure if I have a picture that illustrates it.
In another stroke of genius, got the order of cutting the top of the galley roof down 2" out of order requiring pattern routing the inner panel instead of an easy, single cut operation.
Now that I've been through the process, I have a clearer understanding of how it all goes together.
The biggest time sponge I have is building DIY doors. I'm still glad that I did at this point, but it is very time consuming. I used a pattern for them, but the wall cut-outs didn't turn out to be identical for some reason. I would use a more fool-proof method if I could do that over again to ensure they are identical.
I also didn't realize in my first glue ups of the walls how critical it is to get a bunch of weight all the way around the edge of the plywood being glued together. The are some small, narrow gaps that I had to fill and fix. PL Premium is kind of thick, and apparently needs a lot of pressure to squish it down. Spreading it with a trowel first seems to help, but a lot of pressure is still required.
Over all, I'm very pleased with the TD as it is. I would, however, consider using 3/4" plywood for the skeleton and floor if I were to build it again. I would also use 2x2 tubing for the frame instead of 2x3 as a weight saving measure. Not sure if I would buy the factory built doors though.
Hope this is helpful.
Ryan: I have a sense you are going to use Fredrick's Shop Manual? His hatch building method is straightforward. Just draw out your gusset and counters on your template–to ensure you have room for both.I'm dreading the galley hatch.
kokomoto wrote:Now that I've been through the process, I have a clearer understanding of how it all goes together.
tony.latham wrote:That's really coming together. A nice solid teardrop.
p.s.Ryan: I have a sense you are going to use Fredrick's Shop Manual? His hatch building method is straightforward. Just draw out your gusset and counters on your template–to ensure you have room for both.I'm dreading the galley hatch.
ryan112ryan wrote:
Very helpful! I'm considering buying doors because of how tricky and time consuming they can be. I'm dreading the galley hatch. So many variables
should cancel out the warp.with fingers crossed.
kokomoto wrote:I finally averaged out all the errors...
That's a good one, just like KC's TLAR-That Looks About Right. I'll add my unofficial mottoes, which apply to my working ethic, and directly affect my projects, whether on vehicles, home repairs, and my TTT build, of course: 1)WIT (Whatever It Takes)- I'll do whatever it takes to make something work, and 2)GOOT (Going Off On Tangents)-how I begin with a logical plan, then it takes off into a new direction. And, of course, my under-the-breath catch phrase: DIATH (Darn It All To Hell)-whenever I'm in between GOOT and WIT stages.KCStudly wrote:kokomoto wrote:I finally averaged out all the errors...
I like this phrase. Might make a good name for someone's TD.
Average Out The Errors = AOTA
