DirtyD1833 wrote:Why cut the stud to fit the vent, if the vent has a "lip" just cut the lip to fit around the stud and leave the flange in place. This is my plan when I shamelessly copy flboy's design....
Sent from my SM-T820 using Tapatalk
I've also thought about doing this. Some vent designs would work. But not in my vee. I have one other idea that is 2 smaller vents one on each side of my vee. I'm concerned that in the vee when transporting CTC will have updraft between truck and trailer. This may force air and water into vents. So if I used 2, 6 inch (duct) furnace vents. Something like this
I'd need to block/close them off. So I thought deck plates on the inside of CTC. Well ok, that might be a plan. But how do I put the covers on behind an enclosed AC? Now one other of my problems is I do not want to cut the roof. I don't want my CTC higher. But I have a slanted vee. So could I put a roof vent in the slanted part of the vee? Build a water dam for the upper side ?
I agree that cutting a stud is best done before walls are up. But in my case I didn't want a window until portable failed to keep CTC cool. So I'm limited to where a window unit can go.
I should have planned for the failure and had a secondary prefab in place, for another AC before "completing" my CTC.
Another thing to remember when "copying" is that while different makes of CT's seem the same. There can be differences that go unnoticed until to late. I copied my own loft/lift bed. Knowing bed size would be different. I asked my friends to order a certain trailer. They went to a different CT maker&size. So I had to re figure everything to build the "copy".
But the kicker is their bed came out much nicer than mine.
