Exhaust Duct In Place
Intake Holes
Unit Boxed In
Exhaust Vent Painted (White wasn't going to work for me)
Deflector Idea
jwh92020 wrote:working on it - Is the vent on the top of the ac to exhaust hot air from the coils after it is drawn in through the side intakes? I have 2 - 5" holes on each side of the ac unit thru the floor. Should I mount a fan on one side of the unit and place filters over the holes on the other side? Will the fan provide sufficient air flow, or should/could I an opening in the top of the enclosure and loop a hose into the top of the exhaust duct, or run the hose to a small vent thru the sidewall. I'll try to track down a deflector like yours. thank you for the help.
