Sent from my XT1585 using Tapatalk
The exterior is made from aluminum composite material, which is basically a sandwich made with a polyethylene core and aluminum faces. I bonded the ACM to the plywood walls. To finish it, I am using a vinyl wrap. It is the same material used for vehicle wraps. Basically a great big sticker.Graniterich wrote:Wow, that looks great! Tell us more about the exterior
Sent from my A1-840FHD using Tapatalk
The 3M wrap vinyl is rated at 10 years. I plan on storing the camper indoors, so it should last longer than I do.greygoos wrote:Looking good. I had wondered where you had been. If I remember correctly you are a sign maker. Can you tell me how long you think the wrap might last?
