Acoustic insulation panels have arrived, haven't un-crated them yet.
Today the trailer tongue mounting points were beefed up with stainless hardware (so my novice cold welds are redundant, ahem). A 1000lb boat winch was installed at the front of the tongue, and three eye-hooks were installed at the front bottom of the cabin. With a rope through the eye-hooks and a carabiner connected to the winch the cabin can now be pulled onto the trailer just like a boat. To offload, 4 spring hinged tie-downs will be used on the rear end. With all 7 of these tie down points the cabin can now be offloaded by tying to a tree or another car hitch, anything stationary, and it can be carried by 4 ppl with rope loops. I dream about offloading it onto a layer of straw bales when its stationary for awhile.
Anywho, heres the pics for the day. Enjoy!
- three eye hooks at the bottom of the front
- tnttt_30.jpg (105.95 KiB) Viewed 2739 times
- winch mounting approach, rims cleaned up
- tnttt_31.jpg (151.56 KiB) Viewed 2739 times
- current state of affairs on the trailer - note the 4 stainless steel bolts on the tongue vertices (5th one hidden by the winch)
- tnttt_32.jpg (148.1 KiB) Viewed 2739 times
Oh I forgot to mention one thing... that handle on the winch is
perfect for moving the trailer as its off to the side and its laterally strong (tried to bend it in a vice) but pivots a bit in freewheel mode, but you can lock it either direction for upgrade pulls and downgrade pushes (driveway is a downgrade). Now the trailer has a 'tongue handle'
[Edit: broke the direction pin bolt, drilled it out and replaced it with a bigger bolt, haven't lubed it yet]
