Nichrome wire came in yesterday! Super fast shipping from Washington state to Alabama!
Now to clear out an area to build a cutting table. Working the next few days so will be the weekend before I get anymore done on it.
Took apart a small APC UPS and got the transformer out of it which is a 120 to 15 volt unit, so should work just fine with the heaver wire that I got to cut channels and round the edges with. Will need to dig up a higher voltage transformer to use with the table as it needs to be ~28 volts to heat the 50 inches of wire to 600 degrees.
Got to thinking about it and remembered I had yet another dead APC UPS in the junk pile so tore it down and got the transformer out of it. Turned out to be a higher wattage unit but voltage is the same. Connected the primaries in parallel and the secondaries in series and got 30 volts out at 120 in.
Only need 1.6 amps at 28 volts so should work just fine.
And some pix of the temporary setup to check output voltage.
The transformers wired to the variac.
Variac voltage setting.
And output voltage from the transformers.
Will do a bit neater job of wiring it all up when I get ready to use it.
Unless you know what you are doing, Please DON'T attempt to do this. The voltage/amperage involved can be deadly if proper safety precautions aren't taken.
