featherliteCT1 wrote:flboy wrote:
Good point about using the solar panels to charge while driving. However, I wanted the redundancy and ability to charge at night and during rain. Also, I suppose some guys might not have the roof space for enough panel(s) to generate 20 amps. Just brain storming with you.
My isolator was just an electric solenoid … no diodes.
I have no idea how the OEM computer knows that the OEM battery is full while the deep cycle battery is still low. Most of the literature I read about charging two dissimilar batteries at the same time (wired in parallel) using a conventional bench charger, said that the fullest battery would be over charged while the lower battery was still calling for charge.
Iconfabul8 wrote:As long as you are brainstorming, how about a wind turbine power generating thingy, to charge the batteries while you drive.
McDave wrote:Iconfabul8 wrote:As long as you are brainstorming, how about a wind turbine power generating thingy, to charge the batteries while you drive.
Perfect! Not dependant on sun, I tend to travel (and work etc.) at night when it's hot. Since I'm "generating" wind anyway, why not use that wind? I'm not sure it could add enough drag to even be noticed considering the huge amount of drag I already live with. And the load on the alternator eats horsepower/fuel making it harder to pull the load anyway.
In places like New Mexico, it seems the wind never stops blowing till the sun goes down. So it could do some of the work even when the trailer was static. Very interesting concept.
Just about to hit the road, 12:30 am temp 88 wind sse 25. It could be working right now...![]()
McDave
featherliteCT1 wrote:My 2011 Silverado truck has a 145 amp alternator controlled by a computer with a very sophisticated 7 stage charging algorithm to charge the OEM starter battery...When I installed a deep cycle battery... and tried to use the existing charging system to charge the deep cycle battery, as soon as the OEM battery was fully charged... the alternator stopped generating amps. Consequently, the OEM system would not adequately charge the deep cycle battery....
featherliteCT1 wrote:My 2011 Silverado truck has a 145 amp alternator controlled by a computer with a very sophisticated 7 stage charging algorithm to charge the OEM starter battery and to maintain the proper amps in the system as various loads are applied to the system by the head lights, brake lights, fans, radio, air conditioner, heater, wipers, etc. When I installed a deep cycle battery (with an isolator) and tried to use the existing charging system to charge the deep cycle battery, as soon as the OEM battery was fully charged (which did not take long) the alternator stopped generating amps. Consequently, the OEM system would not adequately charge the deep cycle battery. After much research, I installed the Ctek 250S charger which can provide up to 20 amps utilizing a five stage charging algorithm. The unit was pricey at $238, but it works great.
https://www.etrailer.com/Battery-Charge ... 56676.html
My alternator, like most alternators, is designed to operate continuous duty at no more than about 65% of rated capacity (145amps x 65%= 94 amps maximum), otherwise the diodes in the alternator are at risk of will burning out. Before I bought the Ctek unit, I made sure that the extra 20 amps drawn by the unit would not exceed the 94 amp maximum.
fourbtgait wrote:
That is typical of new vehicles.
I am glad that you have confirmed that this is the case other vehicles.
For me, the toyota 4runner forum provides very indepth knowledge across the board.
Good to know!
I travel with a full charge starting off with the battery. Designed the amp hours of the battery to the draw of the trailer. Have a solar panel to charge when stopped.
Yup!
