6X12 SS&S
Re: 6X12 SS&S
Postby McDave » Fri Aug 11, 2017 11:49 pm
:applause:
:applause: :applause: :applause: :applause: :applause: :applause: :applause: :applause: :applause: :applause: :applause: :applause: :applause: :applause: :applause: :applause: :applause: :applause: :applause: :applause: :applause: :applause: :applause: :applause: :applause: :applause: :applause: :applause: :applause: :applause: :applause: :applause: :applause: :applause: :applause: :applause: :applause: :applause: :applause: :applause: :applause: :applause:
:thumbsup: Awesome!
McDave
McDave
Images: 412
Re: 6X12 SS&S
Postby Iconfabul8 » Sat Aug 12, 2017 1:05 am
featherliteCT1 wrote:I wonder if you could find a PVC end cap with a proper ID that would fit tight over the end? Also, RV stores sell square end caps
I will have to look, maybe heat one up and form it to my odd shape. For now it is going to get a 1/4" bolt thru it.
McDave wrote::applause:
:thumbsup: Awesome!
McDave
Kinda wish all those applauses came with sound! Thats a lot of applause, I feel like I need to stand and bow. :lol: Thanks!
Iconfabul8
Images: 14
Re: 6X12 SS&S
Postby Iconfabul8 » Mon Aug 14, 2017 12:20 am
Unboxed my futon mattress tonight. I'm in the process of building the bed frame. Hopefully some pics in the next few days.
https://www.overstock.com/Home-Garden/F ... oduct.html
Iconfabul8
Images: 14
Re: 6X12 SS&S
Postby Iconfabul8 » Tue Aug 15, 2017 5:59 pm
Wahoo! Just got back from the battery store. Been waiting a long time for these babies!
Iconfabul8
Images: 14
Re: 6X12 SS&S
Postby flboy » Wed Aug 16, 2017 10:49 am
Nice! How many Ah each are those? AGM type? 6V or 12V?
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Re: 6X12 SS&S
Postby Iconfabul8 » Wed Aug 16, 2017 11:28 am
flboy wrote:Nice! How many Ah each are those? AGM type? 6V or 12V?
They are 6 volt, fla, 230 Ah
https://www.batteriesplus.com/productdetails/sligc115
Iconfabul8
Images: 14
Re: 6X12 SS&S
Postby flboy » Wed Aug 16, 2017 11:45 am
You should have great results with those! Now you need some solar to keep them charged! ;-)
Don (Flboy)
flboy
Images: 378
Re: 6X12 SS&S
Postby John61CT » Wed Aug 16, 2017 2:09 pm
Excellent choice in batteries, take care of them properly will last for years.
What shore power charger?
John61CT
Re: 6X12 SS&S
Postby McDave » Wed Aug 16, 2017 8:57 pm
Nice!
McDave
McDave
Images: 412
Re: 6X12 SS&S
Postby Iconfabul8 » Wed Aug 16, 2017 11:00 pm
John61CT wrote:Excellent choice in batteries, take care of them properly will last for years.
I bought a WF 8740 before I learned all you guys prefer the Progressive Dynamics. I'll cross my fingers and hope it hangs with me.
http://wfcoelectronics.com/product/wf-8740-40-amp/
Iconfabul8
Images: 14
Re: 6X12 SS&S
Postby McDave » Wed Aug 16, 2017 11:10 pm
WF-8955 2yrs now. it's the cat's pajamas ;)
McDave
McDave
Images: 412
Re: 6X12 SS&S
Postby John61CT » Thu Aug 17, 2017 12:30 am
40A, that'll do.
My preferred charger is Sterling ProCharge Ultra and ProMariner Pronautic P for custom setpoints
John61CT
Re: 6X12 SS&S
Postby featherliteCT1 » Thu Aug 17, 2017 7:22 am
Iconofabul8,
Many battery manufactures publish the optimum charge parameters for their batteries (the differences between batteries is sometimes quite significant). To my knowledge, Duracell does not publish the optimum charge rates for your batteries.
Your WF-8740 controller outputs 13.2 VDC “float” mode, 13.6 VDC “absorption” charge mode, and a 14.4 VDC “bulk” charge mode. I suspect that these charge rates are close to optimum charge rates for your battery. My Bogart charge controller can be programmed to match any battery charge parameter; but the manufactures' parameters must be known to do so.
FYI, I do not believe there is any shore power charger made that properly charges deep cycle batteries. For example, the Battery Tender web page expressly states that their chargers are not made for deep cycle batteries. Consequently, a solar charger such as yours is the only way I know of to properly charge a deep cycle battery.
featherliteCT1
Re: 6X12 SS&S
Postby flboy » Thu Aug 17, 2017 8:05 am
Some of the better MPPT solar charge controllers will accommodate custom charge parameters also. At the end of the day, I think what you have is good enough.
Optimum is nice, but sometimes optimum and good enough really are not discernable to the average user not pushing the batteries to the limits or claiming marketing specifications.
Its kinda like the audio specs you can't discern with your own ears, but need complex measuring equipment to differentiate. Guys will argue for days over which is better. I say play the music. ;-)
Don (Flboy)
flboy
Images: 378
Re: 6X12 SS&S
Postby John61CT » Thu Aug 17, 2017 8:09 am
featherliteCT1 wrote: To my knowledge, Duracell does not publish the optimum charge rates for your batteries.
Deka does:
The recommendations from East Penn, for that battery, in a cycling / off-grid application are.
(Note: floats are higher in off-grid than typical golf cart use).
At 12V:
Max Charge Current = 30% or less of Ah capacity (20 hour)
Absorption Voltage = 14.4V - 14.7V
Absorption End Point = Current change over 1 hour period of less than 0.1A
Max Absorption Time = 12 Hours
Float Voltage = 13.8V - 14.1V
Float End Time = No Limit
Equalization = 15.0V to 15.3V
Equalization End Point = Current change over 1 hour period of less than 0.1A
Max Equalization Time = 12 Hours
Temp Compensation = -.018V for every degree °C rise above 25C
Note:
For dock charging you may want to compensate float down to 13.4V to 13.6V
the guidance above is for off-grid or deep cycling applications where the batteries are cycled daily.
Stick to the 14.7V end of the absorption range and the batteries will do much better if they are cycled
John61CT
