HALLMARK 6X12 CONVERSION
Re: HALLMARK 6X12 CONVERSION
Postby flboy » Mon Aug 21, 2017 12:29 pm
Tommy B wrote:Don, Just getting it all lined up. I don't know the brand or specs of that TV ANTENNA you loaned me but was just looking at alternatives just in case in case.
Free for Life - Never Pay Your Cable or Satellite For Television Again! 1byone Omni-directional RV TV Antenna can pull in all of your local news, sitcom, kids and sports programs in full HD to any digital-ready TVs, VHF/UHF/FM, VHF: 47-230MHz;UHF: 470-862MHz; FM: 88-108MHz AM: 520-1710KMz.
• Sturdy Mount - The compact mount offers superior wind resistance smaller than traditional RV antennas.
Would this work as good, better, or not at all? :thinking:
I will of course wait and see how yours does first. Maybe just fine.
It looks to be very similar. Same basic shape and similar specs.
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby flboy » Mon Aug 21, 2017 1:40 pm
Tommy, this is what the 24" looks like mounted from a little further away. It is a good size for double duty inside and out. I think you will like it. I actually have two mounts inside so I can watch TV while in bed in the loft or when lounging around in the zero gravity chair below the loft bed. I just pull the pin and move it.
Don (Flboy)
flboy
Images: 378
Postby Tommy B » Mon Aug 21, 2017 1:56 pm
Cant wait. That is very cool what you did there. I will have to figure out how to do that maybe if its possible at this point. Maybe come from underneath. Through the floor. Is That on a mount or just setting there? Seems I would get another mount and attach to trailer exterior?
I plan on bringing this in the house during the off season as I think it would melt in the trailer. Seriously. Do you? Maybe you rig does nor get as hot as mine. :thinking:
Tommy B
Postby flboy » Mon Aug 21, 2017 2:02 pm
Look at my thread. There are some pics there. It is mounted and I made the mount from a lock hasp and a barrel lock slide. It is very small and does the trick. About $13 in hardware. I used stainless so hopefully no rust.
My TVstays in the trailer, but I don't think mine gets as hot as yours inside. In any case, just look at the storage temp specification , and as long as you are not exceeding it, you should be fine. I'd be more worried about long term effect of the humidity.
Don (Flboy)
flboy
Images: 378
Postby Tommy B » Mon Aug 21, 2017 2:33 pm
yes the humidity too.
I may send that mount back. it was only $14.00. I need an easy way to remove the TV for storage.
this one for $44.00 has a mounting plate that the bracket slips into. Two screws and just lift it up and out.
What do you have in the trailer Don. Brand and model # when you get the time please. The one that's coming is garbage I think.
Tommy B
Postby flboy » Mon Aug 21, 2017 2:38 pm
Lets see what you ordered. I modified mine by removing a bolt and making a pin at the swivel joint closest to the TV at the bracket. That is the only reason it removes very easily. In any case, I'll see if I can dig up the info.
Don (Flboy)
flboy
Images: 378
Postby Tommy B » Mon Aug 21, 2017 2:39 pm
hey check the edit please I added a pic. this should do it?
Thanks
Tommy B
Postby flboy » Mon Aug 21, 2017 2:43 pm
That looks nice. The one I have is not as easy. I actually have two mounts inside, but all you would need with that is additional plates . I wonder if it is possible to get one mount and a few mounting plates ? Might swap my setup out. Nice.
Don (Flboy)
flboy
Images: 378
Postby Tommy B » Mon Aug 21, 2017 2:44 pm
also this is what's coming bad reviews, sags when tv is attached. crooked too.
Tommy B
Postby flboy » Mon Aug 21, 2017 3:05 pm
I just may order this one. It comes with two brackets and apparently I can order a third. Will look nicer than the home made one on the side. It will just be a small aluminum plate on the side. Wish I had seen this sooner. Thanks Tommy!
https://www.amazon.com/dp/B00149RVK8/re ... se0MzbSEBH
Edit... just ordered. When I get the details in the box, I will order a third mount bracket. This will be much better for me.
This is shaping up to be a disease! Never done.
Don (Flboy)
flboy
Images: 378
Postby Tommy B » Tue Aug 22, 2017 8:13 am
Don I almost ordered that right off but started to read the reviews. Not good. I will wait and see what you think. I need to read through your thread but I see what you did there on the outside for the TV mount. . Much to think about. Every thing will be here today so I can get started. See what kind of signal I get and then maybe mount the antenna. Need a cable cover again. Maybe giant recreation world has one plus the dicor and butyl tape.
So it goes.
Tommy B
Postby flboy » Tue Aug 22, 2017 8:19 am
I saw the reviews on the on the knob. That is so typical. I will epoxy them like usual with some JB plastic weld when they do fail... and they will. I was most interested in the 2 quick release mounts that come with it and the ability to get a third.
Don (Flboy)
flboy
Images: 378
Postby Tommy B » Tue Aug 22, 2017 9:56 am
Yeah I ordered one too. Its the best out there for what I need. Maybe able to modify with a trip to ace or epoxy. Good luck! :D
I think I may take tomorrow off maybe to get started on it all. Lights, Tv, and antenna.
Don does the tv antenna cable connection stay outside? Please. That 5 inch piece of cable coming off the antenna. How would you weather proof it? It seems to short and you would have to drill a 1/2 hole to poke it in side> :thinking:
Tommy B
Postby flboy » Tue Aug 22, 2017 11:33 am
I'll take some pics of the install or if you want to come by some night before I leave Saturday, I can show you exactly how I installed.
Don (Flboy)
flboy
Images: 378
Postby Tommy B » Tue Aug 22, 2017 11:55 am
ok great. Best to come by for look see. Let you know. thanks :thumbsup:
Tommy B
