6x12 build
Re: 6x12 build
Postby fourbtgait » Sun Aug 27, 2017 10:14 am
No trailer work for a week.
No withdrawls either, to busy fishing...
Silver salmon, then rainbows and dolly varden on flies
fourbtgait
Images: 16
Re: 6x12 build
Postby lrrowe » Sun Aug 27, 2017 1:08 pm
Nice, nice and wow!
Bob
lrrowe
Images: 439
Re: 6x12 build
Postby fourbtgait » Sun Aug 27, 2017 2:23 pm
That was the smallest silver. My wife lost one right at the boat that would have gone 3' long.
All trout were catch and release.
Back to work...
Dinette table in, doors all primed.
fourbtgait
Images: 16
Re: 6x12 build
Postby fourbtgait » Sun Aug 27, 2017 6:06 pm
Water tank in, secured. Hoses for water fill/vent, to pump run. Pump works.
Had one small leak on the water fill hose.
fourbtgait
Images: 16
Re: 6x12 build
Postby Padilen » Sun Aug 27, 2017 6:12 pm
That tank isn't going anywhere!
Padilen
Re: 6x12 build
Postby fourbtgait » Sun Aug 27, 2017 7:45 pm
Makes me wish I had looked at the tank in the TT and 5th wheel to see attachment!
fourbtgait
Images: 16
Re: 6x12 build
Postby fourbtgait » Mon Aug 28, 2017 10:08 pm
Cabinet doors hung, still need latches.
One kitchen drawer in, had the drawer slides left over so was working from memory with them.
Water heater also showed up early, work never stops.
Especially when archery season starts Friday.
fourbtgait
Images: 16
Re: 6x12 build
Postby fourbtgait » Fri Sep 01, 2017 6:57 pm
Drawers in.
Water heater in.
Outside shower in.
Tomorrow will be a pex kind of day.
And no, I have not made provisions for propane yet. Initially was goung to put a tank on the hitch, but leary of the weight with a spare and battery. Thought I would weigh the tongue dry, then loaded. My calculations show a dry weight of about 2,200. Kind of thinking simply carry the tank loose. Have a quick disconnect for the water heater and stove.
fourbtgait
Images: 16
Re: 6x12 build
Postby fourbtgait » Sat Sep 02, 2017 8:45 pm
Plumbing all installed, no leaks. Wife is happy. Just need to run propane to the eater heater.
I did some tongue weight playing. I want a minimum of 300 pound tongue weight. Set up with full water tank, water heater full, weight of rear ice chest, food, then clothes in front (all using free weights from our basement gym), I will need the weight of the spare, battery and propane tank on the hitch. We typically also tale a 45 qt ice chest only for drinks/water, so that will ride in very front compartment. Puts me at 315 tongue weight.
Tomorrow I will pull one of the tires/hubs to get the bearing numbers, then from Etrailer order brakes and hubs. 3,000 pounds of trailer is 60% ov TV capacity and its own weight, so needs breaks for the mountains.
fourbtgait
Images: 16
Re: 6x12 build
Postby RandomAbstract » Sat Sep 02, 2017 10:10 pm
I have been thinking of a build similar to yours. Coming from a teardrop. Love the living outside part of a teardrop. Just need more space. You might encourage me to get started.
RandomAbstract
Re: 6x12 build
Postby McDave » Sun Sep 03, 2017 5:06 am
I think that will be my next upgrade as well. My tow vehicle is a 3/4 ton GMC conversion van and it works well and stops pretty good . But things can get sketchy pretty fast when that 1 1/2 ton trailer is chasing you and trying to push you around in a panic stop. I'll be watching to see how it's done. Seems like I priced it out at about 500-600?
McDave
McDave
Images: 412
Re: 6x12 build
Postby hankaye » Sun Sep 03, 2017 9:07 am
fourbtgait, Howdy;
fourbtgait wrote:Plumbing all installed, no leaks. Wife is happy. Just need to run propane to the eater heater.
When you go to order the brakes etc. don't forget that you'll also be needing a seven-way plug connection
and the wiring for both the trailer and tow vehicle unless the tv already has one. Easier to only pay for shipping once.
hank
hankaye
Re: 6x12 build
Postby fourbtgait » Sun Sep 03, 2017 12:12 pm
McDave wrote:I think that will be my next upgrade as well. My tow vehicle is a 3/4 ton GMC conversion van and it works well and stops pretty good . But things can get sketchy pretty fast when that 1 1/2 ton trailer is chasing you and trying to push you around in a panic stop. I'll be watching to see how it's done. Seems like I priced it out at about 500-600?
McDave
From what I see on Etrailer, both self adjusting brake assemblies are $75. 2 drums are $100. A good controller is $125ish
fourbtgait
Images: 16
Re: 6x12 build
Postby fourbtgait » Sun Sep 03, 2017 12:15 pm
hankaye wrote:fourbtgait, Howdy
hank
I already have a 7 prong plug. Still have a couple 6 prong laying around when they were the standard. TV is already wired. Its easy to install brakes, not my first party. I just need to pull the current hub to get the bearing numbers for verification.
fourbtgait
Images: 16
Re: 6x12 build
Postby fourbtgait » Sun Sep 03, 2017 4:40 pm
Interior trimmed out, need to touch up ceiling paint.
Replace 2 bed supports, though not critical, they are on her side at the head.
All that is left is:
1. Nose tray
2. Propane line
3. Barn door insulation, blocking for drop down table
4. Brakes
I do have a solar panel for it but not going to bother mounting it. We draw so little power.
fourbtgait
Images: 16
