j.hensley wrote:It looks like building my own will be the most feasible option.
I'm really liking the Inka Outdoor trailer style of doors..
DWT77 wrote:j.hensley wrote:It looks like building my own will be the most feasible option.
This build had does that open like that
gallery/image_page.php?album_id=1083&image_id=41419&sk=t&sd=d&st=0
KTM_Guy wrote:I really like the gallwing doors, and have been thinking of them on my build.
Even with all the con's I'm still leaning that way.![]()
SnowLizard wrote:I have gone through this route recently, and even though I have a great concept of this design, it comes down to cost... and the ability to 'mirror' paper to wood.
here's the problems I've encountered designing these...
1) depth and demensions - how deep are they or 'thick' compared to the walls, then after I figure that how am I going to cover up the un-used depth or over-depth of the wall?
2) weight - the wall is designed on 3/4 outside, 1 inch mid and 1/4 inside, that's 2 inches, if the door was the same, how do I water proof that? "T" molding can only do so much, and the curve on the door frame would be a little difficult to make, FORCING a 'solid' frame, all 2 inches worth... this adds weight to the door and frame...
3) latch... all 'easy' latches are paddle handled, they would open by pulling the handle 'down'... were we need the vehicle door type handle Inka has... I have found the hardware from tri-mark... here's a link to the inside bezel.. when cost is added up, it's 150 per side on just the basic hardware, you get to figure out how to mount it up, link it together, and make it work... that's 300 for both doors, PLUS alot of time.
4) the ebay doors are cheaper in time and money in the end... the radius'd 2x3 doors are better for your time and money in the end, they are lighter and IF something goes south on the, replacing the entire door IS an option... where as your custom door, you get to figure it out.
Don't get me wrong, I have tried to design this gallwing door for 4 months, and I'm facing reality, the door itself will add 2-3+ months to my project (1 month plan, 2+ month doing)... where as the pre-made $350 doors will be bolted on in 1 day. it comes down to how much you want to spend on your trailer in time too... me it came down to build time and getting out there in the world, not worry'n about how to make a door work 90* from intended purpose... (yes I have asked the ebay sellers to make me a long door that can do that... )
