I got the composting toilet 90% built yesterday.
Rubber seal around the top to keep it airtight.
Latches to keep the top snug against the seal.
Had to chisel out grooves for the toilet seat hinge, then once it was flush screwed it down.
Had to special order this thing from the UK, couldn't find it anywhere else.
The urine diverter is on a runner so you can slide it forward and back a bit.
I need to add the vent fan, seals to the top lid (on the way, I didn't have any tall enough on hand), an actual bottom, and then whatever I decide the finish will be.
I have some ideas for both modification and for finishing. Seems it would be nice to cut the corners off the front end and have the box angle in. Also I'm thinking about finishing with Aluminum to make it easier to keep clean. We'll see how much gets done now and how much is saved for "future improvements"...
