onehoser wrote:all of my screws were actual screw and came out easy and i reused all of the wood panels and trim.
i have no experience with the 'nail' type screws but i came up with a neat trick when resheathing the floors in my house:
i took a hole saw about 5/8" or 3/4", removed the center drill bit and used that to cut all of the way around the nails through to the joists, then just lifted the sheathing leaving the plug and nail. to keep the hole saw from walking all over the place i cut a hole into a piece of 1/2" plywood, centered it over a nail,stood on it and used it as a guide.
it's much easier to deal with nail screw/plugs once the sheathing's out of the way or you can leave them and they will act as dowels to reinstall the sheathing.
tony
phoenixbound wrote:Just checked. Mine are self-tapping metal screws, which is what I would expect fastening plywood to the metal beam. Strange that they would use something else. Faster and cheaper I guess. Bad thing is the buyer would look at those and assume it's a regular (removable) screw. Learning more all the time.
freeriders98 wrote:So what kind of bit does the exterior and some interior screws take? Its 8 points and not a torx...can get all my paneling off without taking some metal trim off around the doors.
Rainier70 wrote:Number 2 square bit. The screws are a double square
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
