Well Golden Oak won out. I didn't want to muddle over the issue any longer and liked the lighter color as a whole.
I ended up staining for 15 minutes, the longest time the can suggests. I feel like maybe I shouldn't have gone that long. As a result it came out kinda muddy
Mid-staining
Sealed with Spar Urethane - second coat. I also stained the frames but for just a minute, roughly.
Dry fitting the door with handle. Darker than I would have hoped. But still cool! Should look nice when complete.
Polyurethaned all the galley panels as well. No stain.
Nice figure on that one! Mixed with flaws haha.
Satin finish. Did 3 coats.
I've come to realize that I did more of a picture frame construction for the frame portion of the 'frame and panel door' with lined miter cuts. Since reading some woodworking articles I guess its more common to do a mortise and tennon. Live and learn
I also learned that with that picture frame style I should have glued up and sanded the frame first and then stained and sealed it. But... I said it once and I'll say it again
Here is one door gluing together in a Harbor Freight frame thing. Works pretty good. ^pretty results!
Just placed all the handles in their respective areas for this photo before I drill them all in.
Another mistake I've realized about staining and sealing the individual pieces first before gluing them is, obviously the glue isnt taking hold as well as it would on unfinished wood. Its too late to sand the surfaces so I just have to live with it.
The battery door in the galley has its own style handle and hinges different than all the other doors. I tried my hand at chiseling in the spaces to inlay those special handles.
Before I start to place all the doors in I need to update those galley walls with the bead board. I posted earlier saying that I felt like it would make a nicer finish and would give a larger rabbit edge for the galley lip to sit on.
I started to retrofit the new walls.
(plus check out the shiny new galley carcass!)
I first cut the curve of the outer wall then placed that along the galley lid and traced the inside curve to get the proper curve for the wall and galley lid.
The jigsaw was a real tough to use. Im just not good with that thing. So I took it over to my bandsaw and that seemed to work WAY better.
And here it is roughed in!
and here was the before. Much better.
Just need to sand to shape and stain and finish and glue.
Now, I don't want to curse myself but my wife and mines 8 year anniversary is on the 24th of this month (11 days). I'm really not sure 100% if it can be done, but it would blow her mind if I had the trailer finished for that day. Last she saw it I was still dealing with the mold situation, so it would be sure to rock her world to pull up in it. (plus I haven't bought her anything else
) Its ambitious as hell but Im gunna see how far I can get. Even if I dont have all the finishing touches in. Skinned and looking nice will do just fine
Also the seasons are changing and another fall in that leaky garage would really piss me off.
