CanuckShooter wrote:I've come onto a couple old campers and was wondering if I could use one of the fridges as usual...and use another as a freezer in the build I am planning? Do those Dometic RV type fridges get cold enough to use as a freezer?
MtnDon wrote:CanuckShooter wrote:I've come onto a couple old campers and was wondering if I could use one of the fridges as usual...and use another as a freezer in the build I am planning? Do those Dometic RV type fridges get cold enough to use as a freezer?
No, not the std RV fridge.
Esteban wrote:Dometic CFX Fridge/Freezers are rated to cool down to a freezing -7F.
CanuckShooter wrote:Esteban wrote:Dometic CFX Fridge/Freezers are rated to cool down to a freezing -7F.
I've looked at that type here in Canada, and they are very expensive. I already bought a brand new 3 way fridge, but as we are almost always boon docking having more freezer capacity would be a bonus for us.
I found this type which would work when we are out hunting and no 110 is available.
https://bensdiscountsupply.com/unique-2 ... 2-sm-grey/
The more I look, the more a small electric freezer and a small generator may be the way to go.
John61CT wrote:3-way fridges are for powered campsites, the 12V side is only for use while driving, too horribly inefficient for use off batteries.
yes that's huge for solar, an efficient compressor type uses a small fraction of that even when set as a freezer in sweltering conditions.MtnDon wrote:The last full size RV we had with a Norcold 3 way used 10 amps when the fridge ran on 12 VDC.
