Skinning pt. 1
Skinning pt. 1
Postby Jados » Sat Jan 27, 2018 8:45 am
So after looking around and reading everything I could on skins to use and how to install it I finally took the leap and started to skin my teardrop! I ordered two sheets of white 5mm UV resistant frp from a local building supply store. (Incase anyone is interested I paid $50 a sheet) I also bought some gorilla glue exterior high strength multipurpose glue ($4 each).
I then sanded the whole side wall and wiped off any dust with a rag, I then applied the glue covering the whole wall. My wife and I lifted the panel into place careful not to touch the glue until it was in place. Once we got it situated I stapled the first corner and started to push the panel to the wall, working from rear to front and stapling as I went. I used a router with a bearing tipped cutter I cut the front and rear curves, then from the inside I drilled a hole big enough for the router bit and using the router on the outside I cut the door out. I’ll probably be up doing the same on the other side.
I still need to ores the frp for the roof and order the trim, but here’s some pictures of my progress so far.
Jados
Re: Skinning pt. 1
Postby aggie79 » Wed Jan 31, 2018 12:43 pm
Very nice! :thumbsup: :applause: :thumbsup:
I'd like to hear a little more about your 5mm FRP. Do you have a link?
Re: Skinning pt. 1
Postby Jados » Fri Apr 27, 2018 7:37 pm
aggie79 wrote:Very nice! :thumbsup: :applause: :thumbsup:
https://www.homedepot.com/p/4-ft-x-8-ft ... /100389836
It’s this panel except I put the textured side facing the plywood so I could get that cleaner, smoother look.
Jados
Re: Skinning pt. 1
Postby Jados » Tue May 08, 2018 9:02 am
Make sure that if you use frp that it’s warm when you put it on!!! I just looked at mine after the warmup here in the up and it bubbled on both sides!
Jados
Re: Skinning pt. 1
Postby crpngdth2001 » Wed May 09, 2018 5:04 pm
Is that the exact FRP you used in the link? It appears to be ‘interior use’, aka non-uv resistant.
crpngdth2001
