Sent from my ONEPLUS A3000 using Tapatalk
Thanks staryder61!Staryder61 wrote:The framing for the fan, windows and spars looking really good..![]()
Order some pizza, cokes and have a couple students help when you need some extra hands..![]()
Doing a great job clam...
Thanks, thats what I was thinking but needed the confirmation!HarleyCamper wrote:I had used CPES before canvassing because I had planned on skinning with aluminum but had to change to PMF. When trimming the canvas I found that it didn't adhere ad well as I thought or hoped. So I would not treat or seal the plywood before canvassing. The TBII or paint will penetrate the wood whereas if the wood were sealed it can't.
Sent from my SM-G930V using Tapatalk
Staryder61 wrote:Your wire chase did help you out with the wider than 60" width,and when covered you'll know exactly where the front to back wires are run.. only have to mark where the cross wires run to everything,, as to not staple through them when applying the skin, if you use a stapler or pin gun to help with the application of the skin..
