swoody126 wrote:...5ply(usually found in exotic/tropical marine ply) commonly is all veneer ply inside & out w/minimal voids if any
some soft wood marine ply(usually fir) can be found w/ only 3plies of the same material and minimal voids
softwood marine ply will have what was knots filled in w/ football shaped plugs which can be wood or putty therefore claiming minimal voids(i have experienced as many as 11 footballs in a area smaller than 16" x 36")
all that being said the real issue IMHO is the glue
is it stamped on the surface EXTERIOR GLUE or WATERPROOF GLUE?
if not it aint and will eventually fail as moisture eeks it's way into the fibers
the actually measurable thickness isn't as important as the nature of the plies and the glues...sw
working on it wrote: from another thread concerning plywood usage I happened upon a killer deal for pre-sanded, phenolic resin-glued plys, 3/4" plywood (for $25 a sheet)
We are looking for some plywood for the floor 3/4" I guess we will have to order it.![]()
