Very nice, thanks for the info McDave, I'll look into those!
Small suspension update that'll be in progress soon; CJ-7 leaf springs.
The setup I bought for my offroad trailer is all Jeep CJ-7 rear suspension stuff. The GVWR for a entry level, or "light duty" rear leaf spring suspension, is roughly 4150 lbs with ~2,100 of that being for the rear suspension, so I choose to go with the setup assuming they're appropriate for my predicted 1,200-1400 lb trailer without being too overrated for weight. I'm adding shocks to the setup to help dampen the suspension (I'm using the CJ-7 leaf springs perches with a built in lower shock mount to attach the shock at the bottom and running a custom top mount that'll weld to the trailer frame).
To complete the conversion from my stock crap suspension to the CJ-7 suspension, I bought:
- 3 used leaf springs from local recycling yard (2 to use and one for spare)
- leaf spring hangers, shackles, bolts, bushings and bump stops from 4 wheel parts
- custom top shock mount
- my old Tacoma factory rear shocks
Here's the CJ-7 leaf springs I bought, cleaned up and painted:
Here's the link for the CJ-7 suspension diagram to help see what all you need if you choose this route:
https://www.4wheelparts.com/hardpart...aspx?hpDID=134From that diagram, I bought:
2 - #44 Front leaf spring hangers
2 - #37 Front hanger bushings
2 - #39 Spring perches w/ lower shock mounts (they is specific drivers/passenger side part numbers)
2 - #51 Bump stops
2 - #38 Rear shackle kits (includes bushings and bolts needed)
2 - #46 Rear lead spring hangers
2 - ???? U-bolts that fit my 2.38" diameter trailer axle and yet fit the CJ-7 spring perches (forget the part numbers I found)
Hopefully my order from 4wheelparts will be in this week and I'll start fabbing it all up this weekend and update then.
