Attic build - Twin Bed Micro Teardrop
Re: Attic build - Twin Bed Micro Teardrop
Postby atticdrop » Wed Jan 31, 2018 1:48 pm
Hatch skinned. Used 3m VHB tape for some of it. That stuff is the best. I’ll be using more of it.
atticdrop
Postby HarleyCamper » Wed Feb 07, 2018 12:50 am
Looks great. Looking forward to seeing the finished product.
HarleyCamper
Postby dutrisac24 » Fri Feb 16, 2018 12:56 pm
looks good so far, with lots of neat ideas!
dutrisac24
Images: 7
Postby atticdrop » Wed Mar 14, 2018 10:21 pm
atticdrop
Postby aggie79 » Thu Mar 15, 2018 10:09 am
:thumbsup: :applause: :thumbsup:
Postby atticdrop » Mon Mar 19, 2018 9:07 pm
Got some good work done on the trailer. I glued the external walls on with contact cement. I’m thinking of adding screws too, since it will be covered in aluminum. I went overboard with Marine grade plywood, 1/4 inch. I had to cover all the foam with aluminum tape, since the contact cement eats foam.
Three coats of “the mix” (spar urethane and mineral spirits) and it looks pretty darn good!
You can also see a bit of bondo, to smooth the curve where I had to glue two sheets together.
atticdrop
Postby pchast » Tue Mar 20, 2018 9:47 pm
Looking Good!
Outside too. :D
pchast
Images: 97
Postby atticdrop » Wed Mar 21, 2018 6:33 pm
Thanks everyone.
I got a little more done today. I added screws to the side panels since I am not very confident in the contact cement I used. I guess better safe than sorry. This whole project has been overkill.
I should explain my wiring. I am using a 7 pin Trailer connector to allow all lights (backup) and 12 volt charging from the vehicle. I also like how durable the plug is.
I found some really cool taillights from JW speaker that have a separate tail, brake, turn, and backup. Since normal trailer wiring only allows a combined brake/turn, I found a cool vehicle to vehicle relay box from Curt (part #C56196). It allows the turn signal to flash separately from the brake light.
I have a 24 series battery in the back hatch. Overkill again. It is on a 30 amp breaker to the car(also fused on car), just in case. For circuits I am using:
Interior light
Gallery light
Stereo/amp, usb charger, and voltage meter
Vent fan
Exterior (porch) light
Each is on a separate fused circuit. I used a 6 circuit Blue Sea fuse block with grounds.
Wiring for everything is run through the walls and roof. I used 18 gauge marine grade wires everywhere. There are no splices or solder anywhere within the walls. I was very concerned about it being sealed up(no access)so I made sure every wire is accessible at both terminations.
atticdrop
Postby InTheViewfinder » Wed Mar 21, 2018 7:01 pm
Just breezed through these four pages - impressive. Wish I was so handy.
--Rich
InTheViewfinder
Postby atticdrop » Mon Mar 26, 2018 4:51 pm
Sealed up the bottom.
Two coats of “the mix”. Caulked the edges. Then applied Tite Seal window flashing over the whole thing.
atticdrop
Postby Staryder61 » Tue Mar 27, 2018 6:37 pm
Just caught your build,, I agree with rich,, very impressive :thumbsup:
Shows a lot of thought going into the build.. workmanship is #1 :applause:
Love the cherry wood, very good choice..
Be an amazing little camper when you are finished..
Will watch for the updates,, David
Stay safe, David
Our CTC 6' X 12'
Staryder61
Images: 550
Postby atticdrop » Mon Apr 02, 2018 4:04 pm
Thanks everyone! I’m hoping to be using it this summer with my son.
I got outside today with my brother. He came over to help me skin the roof. Man that was hard! We glued the edge with marine sealant/adhesive, and left the middle floating.
atticdrop
Postby atticdrop » Mon Apr 02, 2018 4:05 pm
We’re expecting more snow. So this might be the last update for a bit!
atticdrop
Postby atticdrop » Wed Apr 11, 2018 8:08 pm
Additional photos of the wiring. Excuse the chips.
atticdrop
Postby atticdrop » Mon Apr 23, 2018 8:36 pm
More work today! Snow is gone and making progress.
atticdrop
