Started out at 18° and ended with a high of 34°
Padilen wrote:Happy first day of spring!
Thanks,flboy wrote:Padilen wrote:Happy first day of spring!
I won't rub it in.... but it was 82deg here today. It did rain for a bit tonight though. Tommy and I are going camping the weekend after next... Hopefully we will have some cool evenings.. I don't want to be running the AC in March.
Hopefully it will thaw out there and you can pull Taz out of the barn and get that DRZ loaded up!
Padilen wrote:Have you seen my updated DRZ over on TT?
If not here it is, new used and then not new new
It's a used California model tank, bought it on ADV. Plastics are new ebay RTech and only cost me 79$! Headlight is a Polisport, RMATV. I like its shape but I bought it by mistake. It's only a 30 watt incandescent, I stuck a halogen 40 watt bulb in it. I have a cheap LED bulb to try too.flboy wrote:Padilen wrote:Have you seen my updated DRZ over on TT?
I haven't been out to Thumpertalk in a long time. The DRZ looks nice. So where did you get the tank and plastics from to make it white?![]()
But I want a XTrainer.
Well, it all looks good on there. It appears like a totally different bike. All the mechanical stuff working well?
flboy wrote:Looks like Taz is loaded and ready for business!
Taz really does just fit inside the barn? Is that with the standard tires? Could get some tiny tires to put on for the winter to get her in the barn for the winter when you put the vent on. Also, you could jest take the vent dome off for the winter since it is indoors anyhow? They come off rather easily.
I'd keep that DRZ.. they are rock solid and so much better on the roads. Of course, if you are going to ride like a wild woman in the single track... maybe the 2 smoke is what you need.
Yeah I have thought about other ways. But jacking it up to reinstall stock wheels is difficult. Axle is too low for my floor jacks, with little wheels. So I have to pull up on boards. Then I run out of jack before stock fits. Reset everything and jack it up more. Gets tippie looking with axle flip. And still a lot of work. Should have done 10' doors & 12 walls. I only needed 9' when I built pole barn.hankaye wrote:Padilen, Howdy;
A few years ago there was one member that 'made' a set of metal wheels for his tight clearance fit.
Perhaps you could use a set of rims to give you the space you need to keep it more simple then all
the air out and then air up again/
hank
