by absolutsnwbrdr » Tue Mar 27, 2018 8:35 am
The voltage at the BATT terminals on the charge controller is what is being delivered to the battery, but will not necessarily indicate battery state of charge. So that voltage will be an indication that your charge controller is trying to do its thing, and that's about it.
To get a good idea of battery state of charge, the battery needs to be at rest (no applied voltage, or voltage draw, from any sources) for a period of time (a few hours). After its resting for a while, you can take a voltage measurement at the battery terminals and that will tell you about how full the battery is, but not how much power it has. To do that, you need a power meter measuring wattage and amperage going into the battery. And to know how much power is left in the battery, you would need another power meter to measure the output of the battery. It can get pretty complicated if you want to be super technical.
ZachComing Soon...
