Tom&Shelly wrote:Also, you may want to consider the Power Dynamics PD 4045. It combines converter, 12 v fuse block and circuit breaker box. With your price list, it looks like it may be similar cost, or even a dollar or two little less expensive, and might be more convenient.
wysedav wrote:Thanks for the thoughtful replies.
I seemed to find conflicting info regarding the AC ground when I looked into it. It’s defin an open item for me to research. The two charging options I’m definately open to. I’m going to add the TV charging and provisions for solar. I haven’t calculated my battery size but will before I purchase anything. Probably still need a voltmeter too.
When I’m with my wife I’ll be at a campground with ac my preference is boodicking. The 12vdc utility I considered but couldn’t come up with a good use. But electric blanket makes sense except it will kill my battery quickly. I think I’ll use a panel with circular punch outs so it should be easy to add. I agree with the loads it doesn’t make sense to use so many circuits but I like the idea if homerun type wiring so all of the end connections are accessible, it should make troubleshooting/fixing easier.
David
Its always a giggle when we hear of this nonsense. Talk of tyres insulating adds greatly to the laughter...I'm not sure the advantages to grounding the AC to the frame. I'm not an electrical engineer didn't even stay in a Holiday Inn last night. But you probably already have your 12vdc TV, and the camper battery ground connected to the frame. Does it make sense to add AC into the mix? Also the frame isn't grounded to earth which if you had a fault the electrons are going to be looking for. The rubber tires prevent that. If you have the TV connected to the camper will the electrons flow that way looking for earth? I would not want my TV energized with 120vac.
Btw, even if your trailer is 100% wired perfect, its all for naught if you plug into a improper wired receptacle. Those 'pokelite' testers are helpful, but not a foolpproof receptacle diagnostic instrument.If you run a ground wire to each device and make sure you have a good cord back to the pedestal I would think you are good. Thats my plan. Use one of these at at the pedestal before you plug in, and check a few plugs in the camper and you should know everything is wired right.
So what am I missing that a frame needs to be grounded?
H.A. wrote:Its always a giggle when we hear of this nonsense. Talk of tyres insulating adds greatly to the laughter...I'm not sure the advantages to grounding the AC to the frame. I'm not an electrical engineer didn't even stay in a Holiday Inn last night. But you probably already have your 12vdc TV, and the camper battery ground connected to the frame. Does it make sense to add AC into the mix? Also the frame isn't grounded to earth which if you had a fault the electrons are going to be looking for. The rubber tires prevent that. If you have the TV connected to the camper will the electrons flow that way looking for earth? I would not want my TV energized with 120vac.
When plugged in to mains, Metallic structure of trailer absolutely needs to be connected to earth ground.
An electrical fault to the chassis, (pinched wire for example) will render the chassis electrically 'hot'. If that hot current has no path to earth, somebody standing on earth and touching the trailer becomes the path & gets zapped ! If the car is still hitched, touching the car zapps them too.Btw, even if your trailer is 100% wired perfect, its all for naught if you plug into a improper wired receptacle. Those 'pokelite' testers are helpful, but not a foolpproof receptacle diagnostic instrument.If you run a ground wire to each device and make sure you have a good cord back to the pedestal I would think you are good. Thats my plan. Use one of these at at the pedestal before you plug in, and check a few plugs in the camper and you should know everything is wired right.
I decided to put the battery cut-off switch (s1) and fuse (f1) on the other side of the charger, right off of the battery + terminal. That way, if something shorted in the charger, the fuse would protect the battery. Also, if I wanted to ensure the battery was cut out of everything, the cut-off switch would do that.
...forego a solar panel and the controller for now...
...AC ground attached to the trailer frame…
... you may want to consider the Progressive Dynamics PD 4045...
I noticed the switches you're wanting to use are standard household AC switches…
I second the comment about installing a PD4045…
A Progressive Dynamics PD4045 power center makes wiring easier and safer.
Depending how much money you want to spend up front…
You're running a huge amount of unnecessary wire…
..you need a master fuse and switch close to your AC power inlet…
...always a giggle when we hear of this nonsense…
Scanning through your schematic, it's obvious you're a planner.
I see you've got your USB outlets switched I'm scratching my head a bit on that…
Are the cords at the head or foot end?
Users browsing this forum: Google [Bot] and 0 guests
