Karebru's 7x16 Build Log
Re: Karebru's 7x16 Build Log
Postby Joel.brian » Tue May 08, 2018 8:18 am
Karebru wrote:Looking good.
Is your wall covering reclaimed wood?
Yes, old fence panels that I pressure washed
Joel.brian
Postby PrecisionLook612 » Tue May 08, 2018 8:58 am
Karebru wrote:The first cut is the hardest. ;)
Anybody use a Rotozip for doing window cutouts?
I did my the cut in my roof with a 4 1/2" grinder with a cutoff wheel. It was easier to keep a straight line.
PrecisionLook612
Postby Joel.brian » Tue May 08, 2018 10:31 am
Have you considered the upright portable air conditioners that you can just vent through the wall or through the floor? It might save you a lot of work in the fabrication of the wall mount but they do take up more space.
Joel.brian
Postby John61CT » Tue May 08, 2018 10:39 am
Few of them are effective.
Some of the two-hose ones are.
But a standard window-mount up high works better for low-budget IMO
John61CT
Postby Karebru » Tue May 08, 2018 10:42 am
And the fabrication is half the fun! ;)
I'm not going outside until the temperature is above my age.
Karebru
Postby Joel.brian » Tue May 08, 2018 10:55 am
John61CT wrote:Few of them are effective.
I disagree that they are less effective than a window unit. I would put them about the same. They are cheaper though.
Joel.brian
Postby John61CT » Tue May 08, 2018 3:01 pm
Links to one you recommend would be great. I've seen three different ones didn't work worth a damn, small boats too. Two had only one hose.
One that was barely effective, had two hoses.
John61CT
Postby Joel.brian » Tue May 08, 2018 3:39 pm
John61CT wrote:Links to one you recommend would be great. I've seen three different ones didn't work worth a damn, small boats too. Two had only one hose.
I don’t have a specific one, just in my experience they perform about the same as a window unit. I’m still shopping around for what I want though.
Joel.brian
Postby Iconfabul8 » Tue May 08, 2018 4:13 pm
You might have just opened a nasty can of worms, Haha. There are a long string of portable AC failures on the forum. Most people will agree that the single hose in a small space is worthless because as it blows hot air outside it forms a vacuum in the trailer and sucks hot humid air in from outside. Not as big a problem in a house where you have lots of air to pull from. I'm enjoying the builds, keep up the good work!
Iconfabul8
Images: 14
Postby Joel.brian » Tue May 08, 2018 4:38 pm
Iconfabul8 wrote:You might have just opened a nasty can of worms, Haha. There are a long string of portable AC failures on the forum. Most people will agree that the single hose in a small space is worthless because as it blows hot air outside it forms a vacuum in the trailer and sucks hot humid air in from outside. Not as big a problem in a house where you have lots of air to pull from. I'm enjoying the builds, keep up the good work!
haha that makes sense though
Joel.brian
Postby Karebru » Wed May 09, 2018 4:16 pm
Stuff ordered from Amazon is starting to trickle in. 8)
The fridge is banged up, as was it's packaging. :(
It's going to be built in, so the only dent that matters is the one in the door.
I'd be satisfied with a new door.
We'll see how it goes.
Got my vents and the AC should be here any minute... UPDATE: Just arrived!
Like a kid as Christmas, I tell ya! :lol:
Karebru
Postby flboy » Wed May 09, 2018 6:26 pm
Don't you just love that.. one of my favorite parts of the build was coming home most days and having packages to open. :thumbsup: :thumbsup:
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby Karebru » Wed May 09, 2018 9:29 pm
It's good for the soul to have at least something, no mater how small, to be watching for on package tracking. :thumbsup:
Karebru
Postby Joel.brian » Wed May 09, 2018 11:12 pm
Which AC did you choose?
Joel.brian
Postby Karebru » Thu May 10, 2018 6:03 am
A Frigidaire, 5,000 btu.
I'll make my enclosure big enough for something larger, if it turns out I need it.
Karebru
