Nobes wrote:Great work by your son. Very cool stuff!
Hate to hear about your back. I had similar issues during my build, eventually leading to back surgery. Hope you don't go there.
I hear you on losing motivation. I thought about changing the name of mine to the Frustration.
Wiring: I can't help much, I'm surprised I got mine done. Lots of things on here say the white ground wire just goes to the trailer chassis. When I did that, I had nothing. When I finally grounded each light, everything worked. Not sure that makes sense. It's also ok to find somebody who knows wiring to come to your shop & help! Good luck--
Good looking build, keep going!
swoody126 wrote:there have been 2 different 7-pin configurations over the years
look at the wiring diagram on the back of the packages and then simply compare them to the 'burban's plug
HOWEVER 'taint a wrong idea to have TV charging capability ;-)
7-pin also provides back up light connections
sw
KCStudly wrote:You can check on the electrical forum for details, but be reminded that you want to either disconnect your harness when in camp, or have a turn off relay, so that your camper can't discharge your start battery when the alternator isn't turning.
Staryder61 wrote:KCStudly wrote:You can check on the electrical forum for details, but be reminded that you want to either disconnect your harness when in camp, or have a turn off relay, so that your camper can't discharge your start battery when the alternator isn't turning.
KC, good point.
Disconnecting the harness, will work in camp..
Though, at a roadside park, was thinking of two different alternatives,
1. Running the power from a keyed circuit ( power windows or locks ). Which will disconnect the second battery when key is turned off.
2. Adding a solenoid to the circuit..
I'll check out the electrical forum and see what others have done..
Thanks, David
swoody126 wrote:my Ford's TV > trailer charging system is managed by the ignition switch
when the engine isn't running the circuit is open and therefore doesn't discharge the TV starting batteries
i do have the factory towing pkg
you might check w/ your dealer's service tech about this
sw
Take care of yourself first, I'm sure your family would prefer that. We will all be awaiting your updatesStaryder61 wrote:Small update,, for all our friends..
Raven is on hold again,, GHEEEESH
I started this in November 2017 and thought (OH WOW) can have it done by April 2018..
Did really good for the first few months,, then life and health got in the way. Continues to do so... not certain what will happen next..
Last month was my back, had also found out I had plumbing problems with the veins in my legs .. well left leg was worked on yesterday (Monday).. at Austin Heart and Vein Center.. Let me tell you, they are amazing people there.. everyone was very upbeat yet professional. They did their best to help me stay calm through it all.. because I wasn't when I arrived..
Any way, one leg down .. recovery will not be real long, nothing for 2 days then couple weeks light duty.. then decide when to do the next leg..
As for the Raven,, she's waiting patiently.. Received the fenders yesterday evening for her.. unfortunately when my son opened the box for me to show me.. Both were damaged, dented and scratched pretty bad.. no packaging of any kind inside the box to protect them. so was metal to metal for shipping, contacted etrailer to see what they will do to fix it.. waiting to hear back from them..
Y'all keep pushing a long, and I will be back at it before we know it.. Camp on,, David
Users browsing this forum: twisted lines and 20 guests
