thank you and very helpful! Yes, this is definitely a hobby initiative but believe it can add a lot of value to our build. I was looking at a basic Flux 125 welder from Harbor Freight. Seems easy enough to handle. Any thoughts?domoarigato wrote:Mine is a 220v unit, but a 110v mig welder would work just fine considering the material thickness. If your just looking for a welding machine to use here and there, you could easily settle for one of the ebay inverter welders, under the condition that it has many good reviews. There is lots of chatter put there concerning these off brand knock off welding machines. A LOT are junk, but there are a few decent ones out there that still come with a few risks (no local repair center, should it need repaired you would have to ship it to a regional repair facility) They have become more proficient in duplicating other designs though, and the decent ones seem to be holding up for a fair amount of hobbyist needs. I picked up an AHP 200X AC TIG unit recently for welding aluminum and it has a following of hobbyists that claim its a decent machine. 200A AC/DC high frequency inverter unit with super flexible TIG leads and a flex head torch for $800~. Not bad as long as it holds up, time will tell.
If budget is a concern, you might want to look at the Everlast units. Some claim they are decent, I have never used one myself. Look around at welding machine repair shops and ask what brands they service. I have one in my area that services a lot of brands including a few chinese brands. If you have a bigger budget, you can look at the hardware store Lincoln and Miller units. You'll be looking for something that can run .030 self shielding flux core wire @ 110v 20A or less. Bear in mind the big names still outsource these big box store welders offshore, but the can be serviced at any local welding repair shop should you have any problems. Thermal Arc/Tweco welders are pretty decent as well and can be serviced at most repair shops.
It's a lot of information and something worth researching before buying, but I hope the above helps. Sorry a little scatter brained, actually working on my trailer now and saw the thread notification. Back to work..
-Domo
Sent from my SM-N920V using Tapatalk
rmcrist wrote:thank you and very helpful! Yes, this is definitely a hobby initiative but believe it can add a lot of value to our build. I was looking at a basic Flux 125 welder from Harbor Freight. Seems easy enough to handle. Any thoughts?domoarigato wrote:Mine is a 220v unit, but a 110v mig welder would work just fine considering the material thickness. If your just looking for a welding machine to use here and there, you could easily settle for one of the ebay inverter welders, under the condition that it has many good reviews. There is lots of chatter put there concerning these off brand knock off welding machines. A LOT are junk, but there are a few decent ones out there that still come with a few risks (no local repair center, should it need repaired you would have to ship it to a regional repair facility) They have become more proficient in duplicating other designs though, and the decent ones seem to be holding up for a fair amount of hobbyist needs. I picked up an AHP 200X AC TIG unit recently for welding aluminum and it has a following of hobbyists that claim its a decent machine. 200A AC/DC high frequency inverter unit with super flexible TIG leads and a flex head torch for $800~. Not bad as long as it holds up, time will tell.
-Domo
Sent from my iPhone using Tapatalk Pro
tony.latham wrote:
My better half welding up a chassis for her son's wedding:
Yep, look at my build thread. Steel header, wood window frame. You want to slide a piece of thin sheet metal behind the joint to weld so you don't bubble the exterior paint.rmcrist wrote:When welding the bars inside the trailer to support the windows, is there any precaution to take that will avoid damaging the trailer? I’ve seen people use wood frames around the windows in place of where they cut the whole, but that opens up opportunity for rotting etc.
As JRant said, lots of practice. I was trained in a high school vo-tech program and OJT, but yeah.. youtube videos sll the way. Practice on thin stuff before you weld on the actual trailer struts. Get beyond, blowing hole stage. Manual pulse weld is what you'll want to do with the thin stiff.rmcrist wrote:When welding the bars inside the trailer to support the windows, is there any precaution to take that will avoid damaging the trailer? I’ve seen people use wood frames around the windows in place of where they cut the whole, but that opens up opportunity for rotting etc.
